[Live-demo] Does your application work on the click2try GISVM?
Jody Garnett jody.garnett at gmail.com
Mon Oct 12 22:28:46 EDT 2009
Okay figured it out ...
- chrome did not work
- safari on mac did not work
- it crashed firefox on mac
Trick was to disable the pop up blockers; and then provide access
rights to java app
Testing in safari resulted in:
- geoserver start and install looks good; tasmania map renders
  (complained about previous firefox session)
- udig starts; renders clouds and countries.shp
- renders WMS from geoserver; supported DnD from firefox to uDig catalog
- not able to right click on anything; that seems to be taken up by
the browser not the java applet
- mouse interaction was not response enough to supported editing,
could not drag a point; indeed pointer would get stuck at a particular
location; although it would change shape depending on what you were
actually hovering over.
So about 90% here; enough to demo; not enough to use.
Jody
On Tue, Oct 13, 2009 at 10:03 AM, Jody Garnett <jody.garnett at gmail.com> wrote:
>>>> Log in using
>>>> user id: osgeo password: livedemo
>>>> Once logged in, navigate to My Dashboard/Applications Manager.  You will
>>>> see a VM named osgeo-gisvmsl-2.
>> The Application Manager link does not function for me; it brings up an
>> embedded frame showing a broken link.
> In firefox it shows the connection timing out ... The server at
> scooter.dev.presage-tech.com is taking too long to respond.
> Jody
More information about the Live-demo mailing list
