[Live-demo] Does your application work on the click2try GISVM?
Aneel aneel.r at tecnics.com
Thu Oct 15 08:25:49 EDT 2009
Hello Jody,
uDig is throwing following error while startup.
error:
/usr/bin/udig: line 29:  3026 Segmentation fault
$PRGDIR/udig_internal -data ~/uDigWorkspace $@
Note: If I have applied the "chown -R user.user /usr/lib/udig" command
at first time, then it works fine. Next onwards throwing above error
Please guide me to resolve this issue.
Regards
Aneel
On Thu, 2009-10-15 at 10:29 +1100, Jody Garnett wrote:
> Don't ignore this ... this is the actual testing results:
> Testing in safari resulted in:
> - geoserver start and install looks good; tasmania map renders
>  (complained about previous firefox session)
> - udig starts; renders clouds and countries.shp
> - renders WMS from geoserver; supported DnD from firefox to uDig catalog
> - not able to right click on anything; that seems to be taken up by
> the browser not the java applet
> - mouse interaction was not response enough to supported editing,
> could not drag a point; indeed pointer would get stuck at a particular
> location; although it would change shape depending on what you were
> actually hovering over.
> So about 90% here; enough to demo; not enough to use.
> Jody
> On Tue, Oct 13, 2009 at 1:28 PM, Jody Garnett <jody.garnett at gmail.com> wrote:
> > Okay figured it out ...
> > - chrome did not work
> > - safari on mac did not work
> > - it crashed firefox on mac
> > Trick was to disable the pop up blockers; and then provide access
> > rights to java app
> > Jody
> > On Tue, Oct 13, 2009 at 10:03 AM, Jody Garnett <jody.garnett at gmail.com> wrote:
> >>>>> Log in using
> >>>>> user id: osgeo password: livedemo
> >>>>> Once logged in, navigate to My Dashboard/Applications Manager.  You will
> >>>>> see a VM named osgeo-gisvmsl-2.
> >>> The Application Manager link does not function for me; it brings up an
> >>> embedded frame showing a broken link.
> >> In firefox it shows the connection timing out ... The server at
> >> scooter.dev.presage-tech.com is taking too long to respond.
> >> Jody
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20091015/19267786/attachment.html
More information about the Live-demo mailing list
