[Live-demo] Does your application work on the click2try GISVM?
Aneel aneel.r at tecnics.com
Thu Oct 15 12:00:21 EDT 2009
Hello OSGeo Team,
We have fixed issues and latest click2try-GISVM (osgeo-gisvm20-74) is
available for testing at www.click2try.com.
Know Issue: (Reported to Jody)
/usr/bin/udig: line 29:  3026 Segmentation fault
$PRGDIR/udig_internal -data ~/uDigWorkspace $@
Please let us know if any more issues after testing.
Thanks & Regards
Aneel
click2try
On Thu, 2009-10-15 at 12:32 +0530, Aneel wrote:
> Hello Team,
> Maintenance and bug fix activity is going on click2try-GISVM. Please
> don't try the GISVM on click2try for some time. Once we are done with
> maintenance activity, we will post update on this mailing list.
> Regards
> Aneel
> On Thu, 2009-10-15 at 14:47 +1100, Cameron Shorter wrote:
> > Arun,
> > I've lost track of where geonetwork is up to. I think you had it fixed,
> > and Simon/Jeroen were just updating the automated script for future.
> > Simon, are you able to confirm this?
> > arun.s at tecnics.com wrote:
> > > Hello Cameron,
> > > After reviewing this mail , i think there is something more to be done
> > > to fix this in click2try vm (not sure).
> > > It will be good if (any) steps we need to do on click2try to fix this
> > > issue then please inform us.
> > > FYI , we have already applied the steps metioned by Jeron on currently
> > > running vm.
> > > Arun Sharma
> > > Click2try
> > > *From*: "Simon Pigot" <Simon.Pigot at csiro.au>
> > > *Sent*: Thursday, October 15, 2009 6:33 AM
> > > *To*: "Cameron Shorter" <cameron.shorter at lisasoft.com>
> > > *Subject*: Re: [Live-demo] Does your application work on the click2try
> > > GISVM?
> > > What puzzles me about all this is that the changes Jeroen has made to
> > > the shortcut scripts were actually the way in which the shortcut scripts
> > > were originally submitted!
> > > Cameron, the chown command is in the install_geonetwork.sh already!
> > > The problems seem to have been caused by a decision someone made to
> > > change the uid/gid of user/password (when? how? why?) - is it still
> > > necessary to run the scripts with a sudo to user?
> > > Cheers,
> > > Simon
> > > > Jeroen,
> > > > I hope that we can apply your fixes to the geonetwork install scripts.
> > > > If you have not updated the install_geonetwork.sh , can you please
> > > > describe the issue and fix in the issue tracker, so that we can update
> > > > it before we go through the next release cycle.
> > > http://trac.osgeo.org/osgeo/query?group=status&component=LiveDVD&order=priority
> > > > Jeroen Ticheler wrote:
> > > >> Hi Aneel,
> > > >> These are the changes I did:
> > > >> from the root of the geonetwork application:
> > > >> sudo chown -R user:user *
> > > >> In the shortcuts that start and stop GeoNetwork I removed the first
> > > >> part of the command, just leaving the part:
> > > >> /usr/lib/geonetwork/bin/start-geonetwork.sh
> > > >> or
> > > >> /usr/lib/geonetwork/bin/stop-geonetwork.sh
> > > >> That's all.
> > > >> Ciao,
> > > >> Jeroen
> > > >> ____________________________________________________
> > > >> Jeroen Ticheler
> > > >> De Braakweg 12a
> > > >> 7524 PH Enschede
> > > >> Tel/Fax: +31 (0)53 7370049
> > > >> Mobile: +31 (0)6 81286572
> > > >> http://www.ticheler.net
> > > >> Please consider the environment before printing this email.
> > > >> On Oct 14, 2009, at 1:11 PM, Aneel wrote:
> > > >>> Hello Jeroen,
> > > >>> Please give us the steps you did to fix these issues. Whatever you
> > > doing
> > > >>> is specific to particular instance only. We have to fix them at
> > > >>> application level to make permanent.
> > > >>> Regards
> > > >>> Aneel
> > > >>> click2try
> > > >>> On Wed, 2009-10-14 at 13:05 +0200, Jeroen Ticheler wrote:
> > > >>>> Last thing, I also fixed the start and stop shortcuts. They should
> > > >>>> point directly to the start and stop scripts and not go through the
> > > >>>> launchhelper script.
> > > >>>> Greetings,
> > > >>>> Jeroen
> > > >>>> On Oct 14, 2009, at 12:46 PM, Aneel wrote:
> > > >>>>> Hello Jeroen,
> > > >>>>> don't try the GISVM on click2try for some time.. Once we have
> > > done with
> > > >>>>> Regards
> > > >>>>> Aneel
> > > >>>>> click2try
> > > >>>>> On Wed, 2009-10-14 at 12:41 +0200, Jeroen Ticheler wrote:
> > > >>>>>> Hi Tom,
> > > >>>>>> I tried again several times today. I got some steps further, but
> > > >>>>>> can't
> > > >>>>>> get on to the desktop :-( I use "user/user" as account/pw but
> > > then I
> > > >>>>>> get an error as shown on the screenshot. Is there a way to use SSH?
> > > >>>>>> Kind regards,
> > > >>>>>> Jeroen
> > > >>>>>> Jeroen Ticheler
> > > >>>>>> De Braakweg 12a
> > > >>>>>> 7524 PH Enschede
> > > >>>>>> On Oct 14, 2009, at 1:22 AM, Tom Callaghan wrote:
> > > >>>>>>> Hi Jaroen,
> > > >>>>>>> Maybe I can help you with your connection issues. The message
> > > >>>>>>> "Public Internet Access: Yes, Not available" refers to something
> > > >>>>>>> that has not yet been set up for this VM. This is not a
> > > problem and
> > > >>>>>>> you should still be able to access the VM. When you attempted to
> > > >>>>>>> connect, had you highlighted the VM osgeo-gisvm20-25 and click2ed
> > > >>>>>>> the LAUNCH button? If so, what happens? Do you see a light purple
> > > >>>>>>> screen with a progress bar across the top? Do you receive a
> > > message
> > > >>>>>>> for installing a click2try java applet? Does a frame with a page
> > > >>>>>>> not found appear on the left side of the screen with a title bar
> > > >>>>>>> "quickstart guide"?
> > > >>>>>>> Tom
> > > >>>>>>> From: Jeroen Ticheler [mailto:Jeroen at Ticheler.net]
> > > >>>>>>> Sent: Tuesday, October 13, 2009 5:41 PM
> > > >>>>>>> To: Aneel
> > > >>>>>>> Cc: Cameron Shorter; Ricardo Pinho; Tom Callaghan; Arun Sharma
> > > >>>>>>> Tecnics
> > > >>>>>>> Subject: Re: [Live-demo] Does your application work on the
> > > click2try
> > > >>>>>>> GISVM?
> > > >>>>>>> Hi Aneel,
> > > >>>>>>> I tried to connect and have a look. I can't get access, maybe
> > > >>>>>>> because someone else is using the VM, is that correct? I read
> > > >>>>>>> "Public Internet Access: Yes, Not available" and I see one user
> > > >>>>>>> online.
> > > >>>>>>> Concerning the problem, the first two lines are normal for a very
> > > >>>>>>> first time startup. The following three lines are not and indicate
> > > >>>>>>> that the permissions of the account running the application don't
> > > >>>>>>> allow writing to the logs directory. Most likely the same is true
> > > >>>>>>> for some other directories that GeoNetwork needs to be able to
> > > write
> > > >>>>>>> to. I suggest reviewing the privileges of the process owner to
> > > >>>>>>> ensure that write privileges are given to the GeoNetwork
> > > application
> > > >>>>>>> folders.
> > > >>>>>>> Let me know if I can help further.
> > > >>>>>>> Kind regards,
> > > >>>>>>> Jeroen
> > > >>>>>>> ps. I will be on my way to Sydney from Thursday morning onwards
> > > >>>>>>> (Amsterdam time zone).
> > > >>>>>>> On Oct 13, 2009, at 8:54 PM, Aneel wrote:
> > > >>>>>>> Issue2: (GeoNetwork - it doesn't work)
> > > >>>>>>> Launching /usr/lib/geonetwork/bin/start-geonetwork.sh
> > > >>>>>>> rm: cannot remove `logs/*request.log*': No such file or directory
> > > >>>>>>> rm: cannot remove `logs/output.log': No such file or directory
> > > >>>>>>> mv: cannot stat `logs/geonetwork.log.*': No such file or directory
> > > >>>>>>> mv: cannot stat `logs/intermap.log.*': No such file or directory
> > > >>>>>>> mv: cannot stat `logs/geoserver.log.*': No such file or directory
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20091015/12c4960c/attachment-0001.html
More information about the Live-demo mailing list
