[Live-demo] Does your application work on the click2try GISVM?
Dane Springmeyer blake at hailmail.net
Thu Oct 15 12:51:21 EDT 2009
I just tried the latest VM '20-74' and now see a Segmentation Fault
when running the default python.
Open a terminal and type 'python' and this is what you get:
user at osgeo-gisvm20-74:~$ python
Segmentation fault
but python2.5 works:
user at osgeo-gisvm20-74:~$ python2.5
 >>> # all good...
Really odd, I've never seen a segfault like this with python after
just starting the interpreter.
Dane
On Oct 15, 2009, at 9:00 AM, Aneel wrote:
> Hello OSGeo Team,
> We have fixed issues and latest click2try-GISVM (osgeo-gisvm20-74)
> is available for testing at www.click2try.com.
> Know Issue: (Reported to Jody)
> /usr/bin/udig: line 29:  3026 Segmentation fault      $PRGDIR/
> udig_internal -data ~/uDigWorkspace $@
> Please let us know if any more issues after testing.
> Thanks & Regards
> Aneel
> click2try
> On Thu, 2009-10-15 at 12:32 +0530, Aneel wrote:
>> Hello Team,
>> Maintenance and bug fix activity is going on click2try-GISVM. Please
>> don't try the GISVM on click2try for some time. Once we are done with
>> maintenance activity, we will post update on this mailing list.
>> Regards
>> Aneel
>> On Thu, 2009-10-15 at 14:47 +1100, Cameron Shorter wrote:
>> > Arun,
>> > I've lost track of where geonetwork is up to. I think you had it
>> fixed,
>> > and Simon/Jeroen were just updating the automated script for
>> future.
>> > Simon, are you able to confirm this?
>> > arun.s at tecnics.com wrote:
>> > > Hello Cameron,
>> > > After reviewing this mail , i think there is something more to
>> be done
>> > > to fix this in click2try vm (not sure).
>> > > It will be good if (any) steps we need to do on click2try to
>> fix this
>> > > issue then please inform us.
>> > > FYI , we have already applied the steps metioned by Jeron on
>> currently
>> > > running vm.
>> > > Arun Sharma
>> > > Click2try
>> > > *From*: "Simon Pigot" <Simon.Pigot at csiro.au>
>> > > *Sent*: Thursday, October 15, 2009 6:33 AM
>> > > *To*: "Cameron Shorter" <cameron.shorter at lisasoft.com>
>> > > *Subject*: Re: [Live-demo] Does your application work on the
>> click2try
>> > > GISVM?
>> > > What puzzles me about all this is that the changes Jeroen has
>> made to
>> > > the shortcut scripts were actually the way in which the
>> shortcut scripts
>> > > were originally submitted!
>> > > Cameron, the chown command is in the install_geonetwork.sh
>> already!
>> > > The problems seem to have been caused by a decision someone
>> made to
>> > > change the uid/gid of user/password (when? how? why?) - is it
>> still
>> > > necessary to run the scripts with a sudo to user?
>> > > Cheers,
>> > > Simon
>> > > > Jeroen,
>> > > > I hope that we can apply your fixes to the geonetwork install
>> scripts.
>> > > > If you have not updated the install_geonetwork.sh , can you
>> please
>> > > > describe the issue and fix in the issue tracker, so that we
>> can update
>> > > > it before we go through the next release cycle.
>> > > http://trac.osgeo.org/osgeo/query?group=status&component=LiveDVD&order=priority
>> > > > Jeroen Ticheler wrote:
>> > > >> Hi Aneel,
>> > > >> These are the changes I did:
>> > > >> from the root of the geonetwork application:
>> > > >> sudo chown -R user:user *
>> > > >> In the shortcuts that start and stop GeoNetwork I removed
>> the first
>> > > >> part of the command, just leaving the part:
>> > > >> /usr/lib/geonetwork/bin/start-geonetwork.sh
>> > > >> or
>> > > >> /usr/lib/geonetwork/bin/stop-geonetwork.sh
>> > > >> That's all.
>> > > >> Ciao,
>> > > >> Jeroen
>> > > >> ____________________________________________________
>> > > >> Jeroen Ticheler
>> > > >> De Braakweg 12a
>> > > >> 7524 PH Enschede
>> > > >> Tel/Fax: +31 (0)53 7370049
>> > > >> Mobile: +31 (0)6 81286572
>> > > >> http://www.ticheler.net
>> > > >> Please consider the environment before printing this email.
>> > > >> On Oct 14, 2009, at 1:11 PM, Aneel wrote:
>> > > >>> Hello Jeroen,
>> > > >>> Please give us the steps you did to fix these issues.
>> Whatever you
>> > > doing
>> > > >>> is specific to particular instance only. We have to fix
>> them at
>> > > >>> application level to make permanent.
>> > > >>> Regards
>> > > >>> Aneel
>> > > >>> click2try
>> > > >>> On Wed, 2009-10-14 at 13:05 +0200, Jeroen Ticheler wrote:
>> > > >>>> Last thing, I also fixed the start and stop shortcuts.
>> They should
>> > > >>>> point directly to the start and stop scripts and not go
>> through the
>> > > >>>> launchhelper script.
>> > > >>>> Greetings,
>> > > >>>> Jeroen
>> > > >>>> On Oct 14, 2009, at 12:46 PM, Aneel wrote:
>> > > >>>>> Hello Jeroen,
>> GISVM. Please
>> > > >>>>> don't try the GISVM on click2try for some time.. Once we
>> have
>> > > done with
>> list.
>> > > >>>>> Regards
>> > > >>>>> Aneel
>> > > >>>>> click2try
>> > > >>>>> On Wed, 2009-10-14 at 12:41 +0200, Jeroen Ticheler wrote:
>> > > >>>>>> Hi Tom,
>> > > >>>>>> I tried again several times today. I got some steps
>> further, but
>> > > >>>>>> can't
>> > > >>>>>> get on to the desktop :-( I use "user/user" as account/
>> pw but
>> > > then I
>> > > >>>>>> get an error as shown on the screenshot. Is there a way
>> to use SSH?
>> > > >>>>>> Kind regards,
>> > > >>>>>> Jeroen
>> > > >>>>>> Jeroen Ticheler
>> > > >>>>>> De Braakweg 12a
>> > > >>>>>> 7524 PH Enschede
>> email.
>> > > >>>>>> On Oct 14, 2009, at 1:22 AM, Tom Callaghan wrote:
>> > > >>>>>>> Hi Jaroen,
>> > > >>>>>>> Maybe I can help you with your connection issues. The
>> message
>> > > >>>>>>> "Public Internet Access: Yes, Not available" refers to
>> something
>> > > >>>>>>> that has not yet been set up for this VM. This is not a
>> > > problem and
>> > > >>>>>>> you should still be able to access the VM. When you
>> attempted to
>> > > >>>>>>> connect, had you highlighted the VM osgeo-gisvm20-25
>> and click2ed
>> > > >>>>>>> the LAUNCH button? If so, what happens? Do you see a
>> light purple
>> > > >>>>>>> screen with a progress bar across the top? Do you
>> receive a
>> > > message
>> > > >>>>>>> for installing a click2try java applet? Does a frame
>> with a page
>> > > >>>>>>> not found appear on the left side of the screen with a
>> title bar
>> > > >>>>>>> "quickstart guide"?
>> > > >>>>>>> Tom
>> > > >>>>>>> From: Jeroen Ticheler [mailto:Jeroen at Ticheler.net]
>> > > >>>>>>> Sent: Tuesday, October 13, 2009 5:41 PM
>> > > >>>>>>> To: Aneel
>> > > >>>>>>> Cc: Cameron Shorter; Ricardo Pinho; Tom Callaghan; Arun
>> Sharma
>> > > >>>>>>> Tecnics
>> > > >>>>>>> Subject: Re: [Live-demo] Does your application work on
>> the
>> > > click2try
>> > > >>>>>>> GISVM?
>> > > >>>>>>> Hi Aneel,
>> > > >>>>>>> I tried to connect and have a look. I can't get access,
>> maybe
>> > > >>>>>>> because someone else is using the VM, is that correct?
>> I read
>> > > >>>>>>> "Public Internet Access: Yes, Not available" and I see
>> one user
>> > > >>>>>>> online.
>> > > >>>>>>> Concerning the problem, the first two lines are normal
>> for a very
>> > > >>>>>>> first time startup. The following three lines are not
>> and indicate
>> > > >>>>>>> that the permissions of the account running the
>> application don't
>> > > >>>>>>> allow writing to the logs directory. Most likely the
>> same is true
>> > > >>>>>>> for some other directories that GeoNetwork needs to be
>> able to
>> > > write
>> > > >>>>>>> to. I suggest reviewing the privileges of the process
>> owner to
>> > > >>>>>>> ensure that write privileges are given to the GeoNetwork
>> > > application
>> > > >>>>>>> folders.
>> > > >>>>>>> Let me know if I can help further.
>> > > >>>>>>> Kind regards,
>> > > >>>>>>> Jeroen
>> > > >>>>>>> ps. I will be on my way to Sydney from Thursday morning
>> onwards
>> > > >>>>>>> (Amsterdam time zone).
>> > > >>>>>>> On Oct 13, 2009, at 8:54 PM, Aneel wrote:
>> > > >>>>>>> Issue2: (GeoNetwork - it doesn't work)
>> > > >>>>>>> Launching /usr/lib/geonetwork/bin/start-geonetwork.sh
>> > > >>>>>>> rm: cannot remove `logs/*request.log*': No such file or
>> directory
>> > > >>>>>>> rm: cannot remove `logs/output.log': No such file or
>> directory
>> > > >>>>>>> mv: cannot stat `logs/geonetwork.log.*': No such file
>> or directory
>> > > >>>>>>> mv: cannot stat `logs/intermap.log.*': No such file or
>> directory
>> > > >>>>>>> mv: cannot stat `logs/geoserver.log.*': No such file or
>> directory
>> Live-demo mailing list
>> Live-demo at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/live-demo
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20091015/20434b26/attachment-0001.html
More information about the Live-demo mailing list
