[Live-demo] Does your application work on the click2try GISVM?
Dane Springmeyer blake at hailmail.net
Thu Oct 15 13:13:08 EDT 2009
Running `strace python` gives an Illegal Instruction:
http://dpaste.com/107722/
I wonder if the read-only user mode is the culprit.
Dane
On Oct 15, 2009, at 9:51 AM, Dane Springmeyer wrote:
> I just tried the latest VM '20-74' and now see a Segmentation Fault
> when running the default python.
> Open a terminal and type 'python' and this is what you get:
> user at osgeo-gisvm20-74:~$ python
> Segmentation fault
> but python2.5 works:
> user at osgeo-gisvm20-74:~$ python2.5
> >>> # all good...
> Really odd, I've never seen a segfault like this with python after
> just starting the interpreter.
> Dane
> On Oct 15, 2009, at 9:00 AM, Aneel wrote:
>> Hello OSGeo Team,
>> We have fixed issues and latest click2try-GISVM (osgeo-gisvm20-74)
>> is available for testing at www.click2try.com.
>> Know Issue: (Reported to Jody)
>> /usr/bin/udig: line 29:  3026 Segmentation fault      $PRGDIR/
>> udig_internal -data ~/uDigWorkspace $@
>> Please let us know if any more issues after testing.
>> Thanks & Regards
>> Aneel
>> click2try
>> On Thu, 2009-10-15 at 12:32 +0530, Aneel wrote:
>>> Hello Team,
>>> Maintenance and bug fix activity is going on click2try-GISVM. Please
>>> don't try the GISVM on click2try for some time. Once we are done
>>> with
>>> maintenance activity, we will post update on this mailing list.
>>> Regards
>>> Aneel
>>> On Thu, 2009-10-15 at 14:47 +1100, Cameron Shorter wrote:
>>> > Arun,
>>> > I've lost track of where geonetwork is up to. I think you had it
>>> fixed,
>>> > and Simon/Jeroen were just updating the automated script for
>>> future.
>>> > Simon, are you able to confirm this?
>>> > arun.s at tecnics.com wrote:
>>> > > Hello Cameron,
>>> > > After reviewing this mail , i think there is something more to
>>> be done
>>> > > to fix this in click2try vm (not sure).
>>> > > It will be good if (any) steps we need to do on click2try to
>>> fix this
>>> > > issue then please inform us.
>>> > > FYI , we have already applied the steps metioned by Jeron on
>>> currently
>>> > > running vm.
>>> > > Arun Sharma
>>> > > Click2try
>>> > > *From*: "Simon Pigot" <Simon.Pigot at csiro.au>
>>> > > *Sent*: Thursday, October 15, 2009 6:33 AM
>>> > > *To*: "Cameron Shorter" <cameron.shorter at lisasoft.com>
>>> > > *Subject*: Re: [Live-demo] Does your application work on the
>>> click2try
>>> > > GISVM?
>>> > > What puzzles me about all this is that the changes Jeroen has
>>> made to
>>> > > the shortcut scripts were actually the way in which the
>>> shortcut scripts
>>> > > were originally submitted!
>>> > > Cameron, the chown command is in the install_geonetwork.sh
>>> already!
>>> > > The problems seem to have been caused by a decision someone
>>> made to
>>> > > change the uid/gid of user/password (when? how? why?) - is it
>>> still
>>> > > necessary to run the scripts with a sudo to user?
>>> > > Cheers,
>>> > > Simon
>>> > > > Jeroen,
>>> > > > I hope that we can apply your fixes to the geonetwork
>>> install scripts.
>>> > > > If you have not updated the install_geonetwork.sh , can you
>>> please
>>> > > > describe the issue and fix in the issue tracker, so that we
>>> can update
>>> > > > it before we go through the next release cycle.
>>> > > http://trac.osgeo.org/osgeo/query?group=status&component=LiveDVD&order=priority
>>> > > > Jeroen Ticheler wrote:
>>> > > >> Hi Aneel,
>>> > > >> These are the changes I did:
>>> > > >> from the root of the geonetwork application:
>>> > > >> sudo chown -R user:user *
>>> > > >> In the shortcuts that start and stop GeoNetwork I removed
>>> the first
>>> > > >> part of the command, just leaving the part:
>>> > > >> /usr/lib/geonetwork/bin/start-geonetwork.sh
>>> > > >> or
>>> > > >> /usr/lib/geonetwork/bin/stop-geonetwork.sh
>>> > > >> That's all.
>>> > > >> Ciao,
>>> > > >> Jeroen
>>> > > >> ____________________________________________________
>>> > > >> Jeroen Ticheler
>>> > > >> De Braakweg 12a
>>> > > >> 7524 PH Enschede
>>> > > >> Tel/Fax: +31 (0)53 7370049
>>> > > >> Mobile: +31 (0)6 81286572
>>> > > >> http://www.ticheler.net
>>> > > >> Please consider the environment before printing this email.
>>> > > >> On Oct 14, 2009, at 1:11 PM, Aneel wrote:
>>> > > >>> Hello Jeroen,
>>> > > >>> Please give us the steps you did to fix these issues.
>>> Whatever you
>>> > > doing
>>> > > >>> is specific to particular instance only. We have to fix
>>> them at
>>> > > >>> application level to make permanent.
>>> > > >>> Regards
>>> > > >>> Aneel
>>> > > >>> click2try
>>> > > >>> On Wed, 2009-10-14 at 13:05 +0200, Jeroen Ticheler wrote:
>>> > > >>>> Last thing, I also fixed the start and stop shortcuts.
>>> They should
>>> > > >>>> point directly to the start and stop scripts and not go
>>> through the
>>> > > >>>> launchhelper script.
>>> > > >>>> Greetings,
>>> > > >>>> Jeroen
>>> > > >>>> On Oct 14, 2009, at 12:46 PM, Aneel wrote:
>>> > > >>>>> Hello Jeroen,
>>> GISVM. Please
>>> > > >>>>> don't try the GISVM on click2try for some time.. Once we
>>> have
>>> > > done with
>>> mailing list.
>>> > > >>>>> Regards
>>> > > >>>>> Aneel
>>> > > >>>>> click2try
>>> > > >>>>> On Wed, 2009-10-14 at 12:41 +0200, Jeroen Ticheler wrote:
>>> > > >>>>>> Hi Tom,
>>> > > >>>>>> I tried again several times today. I got some steps
>>> further, but
>>> > > >>>>>> can't
>>> > > >>>>>> get on to the desktop :-( I use "user/user" as account/
>>> pw but
>>> > > then I
>>> > > >>>>>> get an error as shown on the screenshot. Is there a way
>>> to use SSH?
>>> > > >>>>>> Kind regards,
>>> > > >>>>>> Jeroen
>>> > > >>>>>> Jeroen Ticheler
>>> > > >>>>>> De Braakweg 12a
>>> > > >>>>>> 7524 PH Enschede
>>> email.
>>> > > >>>>>> On Oct 14, 2009, at 1:22 AM, Tom Callaghan wrote:
>>> > > >>>>>>> Hi Jaroen,
>>> > > >>>>>>> Maybe I can help you with your connection issues. The
>>> message
>>> > > >>>>>>> "Public Internet Access: Yes, Not available" refers to
>>> something
>>> > > >>>>>>> that has not yet been set up for this VM. This is not a
>>> > > problem and
>>> > > >>>>>>> you should still be able to access the VM. When you
>>> attempted to
>>> > > >>>>>>> connect, had you highlighted the VM osgeo-gisvm20-25
>>> and click2ed
>>> > > >>>>>>> the LAUNCH button? If so, what happens? Do you see a
>>> light purple
>>> > > >>>>>>> screen with a progress bar across the top? Do you
>>> receive a
>>> > > message
>>> > > >>>>>>> for installing a click2try java applet? Does a frame
>>> with a page
>>> > > >>>>>>> not found appear on the left side of the screen with a
>>> title bar
>>> > > >>>>>>> "quickstart guide"?
>>> > > >>>>>>> Tom
>>> > > >>>>>>> From: Jeroen Ticheler [mailto:Jeroen at Ticheler.net]
>>> > > >>>>>>> Sent: Tuesday, October 13, 2009 5:41 PM
>>> > > >>>>>>> To: Aneel
>>> > > >>>>>>> Cc: Cameron Shorter; Ricardo Pinho; Tom Callaghan;
>>> Arun Sharma
>>> > > >>>>>>> Tecnics
>>> > > >>>>>>> Subject: Re: [Live-demo] Does your application work on
>>> the
>>> > > click2try
>>> > > >>>>>>> GISVM?
>>> > > >>>>>>> Hi Aneel,
>>> > > >>>>>>> I tried to connect and have a look. I can't get
>>> access, maybe
>>> > > >>>>>>> because someone else is using the VM, is that correct?
>>> I read
>>> > > >>>>>>> "Public Internet Access: Yes, Not available" and I see
>>> one user
>>> > > >>>>>>> online.
>>> > > >>>>>>> Concerning the problem, the first two lines are normal
>>> for a very
>>> > > >>>>>>> first time startup. The following three lines are not
>>> and indicate
>>> > > >>>>>>> that the permissions of the account running the
>>> application don't
>>> > > >>>>>>> allow writing to the logs directory. Most likely the
>>> same is true
>>> > > >>>>>>> for some other directories that GeoNetwork needs to be
>>> able to
>>> > > write
>>> > > >>>>>>> to. I suggest reviewing the privileges of the process
>>> owner to
>>> > > >>>>>>> ensure that write privileges are given to the GeoNetwork
>>> > > application
>>> > > >>>>>>> folders.
>>> > > >>>>>>> Let me know if I can help further.
>>> > > >>>>>>> Kind regards,
>>> > > >>>>>>> Jeroen
>>> > > >>>>>>> ps. I will be on my way to Sydney from Thursday
>>> morning onwards
>>> > > >>>>>>> (Amsterdam time zone).
>>> > > >>>>>>> On Oct 13, 2009, at 8:54 PM, Aneel wrote:
>>> > > >>>>>>> Issue2: (GeoNetwork - it doesn't work)
>>> > > >>>>>>> Launching /usr/lib/geonetwork/bin/start-geonetwork.sh
>>> > > >>>>>>> rm: cannot remove `logs/*request.log*': No such file
>>> or directory
>>> > > >>>>>>> rm: cannot remove `logs/output.log': No such file or
>>> directory
>>> > > >>>>>>> mv: cannot stat `logs/geonetwork.log.*': No such file
>>> or directory
>>> > > >>>>>>> mv: cannot stat `logs/intermap.log.*': No such file or
>>> directory
>>> > > >>>>>>> mv: cannot stat `logs/geoserver.log.*': No such file
>>> or directory
>>> Live-demo mailing list
>>> Live-demo at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/live-demo
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20091015/37cbf406/attachment-0001.html
More information about the Live-demo mailing list
