[Live-demo] Does your application work on the click2try GISVM?
arun.s at tecnics.com arun.s at tecnics.com
Thu Oct 15 23:47:35 EDT 2009
Hello Jody,
Just thought to share my thougts regarding this issue.
"Next onwards" means when a particular instance of vm is created and
persmission is set using command "chown -R user.user /usr/lib/udig" , we
can run "udig"  and application runs perfectly. We can close the udig
application and start again. Starting udig again also works for us.
When we close the virtual machine and saved it. After opening the vm udig
does not work and we get seg fault error.
Yes, udig stuff is present in /usr/lib/udig directory.
Arun sharma
Click2try
Sent: Friday, October 16, 2009 4:08 AM
To: "Aneel" <aneel.r at tecnics.com>, "andrea antonello"
<andrea.antonello at gmail.com>
Subject: Re: [Live-demo] Does your application work on the click2try GISVM?
Morning Aneel:
On of the udig-devel (Andrea is CCed) has asked what the contents of
your udig script is; I went looking on the live dvd and could not find
where things were located.
Okay mark helped me; normal udig stuff seems to occur in /usr/lib/udig
Jody
On Fri, Oct 16, 2009 at 8:23 AM, Jody Garnett wrote:
> I have passed your email on to the udig-devel list.
> What do you mean by "next onwards"?
> It does sound like you are running into permission problems. The command
> line parameters for uDig are documented here.
http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse.platform.doc.isv
/reference/misc/runtime-options.html
> My guess is that it wants to write into a directory which it cannot?
> I believe that this discussion has occurred too late before the
conference
> for me to help you; you will need to distribute without uDig working.
Either
> remove it or place a note in the read me.
> Jody
> On 15/10/2009, at 11:25 PM, Aneel wrote:
> Hello Jody,
> uDig is throwing following error while startup.
> error:
> /usr/bin/udig: line 29:  3026 Segmentation fault
$PRGDIR/udig_internal
> -data ~/uDigWorkspace $@
> Note: If I have applied the "chown -R user.user /usr/lib/udig" command
at
> first time, then it works fine. Next onwards throwing above error
> Please guide me to resolve this issue.
> Regards
> Aneel
> On Thu, 2009-10-15 at 10:29 +1100, Jody Garnett wrote:
> Don't ignore this ... this is the actual testing results:
> Testing in safari resulted in:
> - geoserver start and install looks good; tasmania map renders
> (complained about previous firefox session)
> - udig starts; renders clouds and countries.shp
> - renders WMS from geoserver; supported DnD from firefox to uDig catalog
> - not able to right click on anything; that seems to be taken up by
> the browser not the java applet
> - mouse interaction was not response enough to supported editing,
> could not drag a point; indeed pointer would get stuck at a particular
> location; although it would change shape depending on what you were
> actually hovering over.
> So about 90% here; enough to demo; not enough to use.
> Jody
> On Tue, Oct 13, 2009 at 1:28 PM, Jody Garnett
> wrote:
>> Okay figured it out ...
>> - chrome did not work
>> - safari on mac did not work
>> - it crashed firefox on mac
>> Trick was to disable the pop up blockers; and then provide access
>> rights to java app
catalog
>> Jody
>> On Tue, Oct 13, 2009 at 10:03 AM, Jody Garnett
>> wrote:
>>>>>> Log in using
>>>>>> user id: osgeo password: livedemo
>>>>>> Once logged in, navigate to My Dashboard/Applications Manager.  You
>>>>>> will
>>>>>> see a VM named osgeo-gisvmsl-2.
>>>> The Application Manager link does not function for me; it brings up
an
>>>> embedded frame showing a broken link.
>>> In firefox it shows the connection timing out ... The server at
>>> scooter.dev.presage-tech.com is taking too long to respond.
>>> Jody
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20091015/b8264898/attachment.html
More information about the Live-demo mailing list
