[Live-demo] java version on the live dvd?
Judit Mays mays at lat-lon.de
Mon Sep 14 09:18:57 EDT 2009
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hello list,
deegree is happy to run with Java5 or Java6
deegree is picky about the Java "supplier": we want SUN-Java only.
would it be possible to set the JAVA_HOME variable globally so all Java
projects can use it?
Just to be on the safe side, I will add this to the deegree scripts anyway.
Kind regards,
Judit
Cameron Shorter schrieb:
> Java projects:
> I'd like to know which version of java your applications:
> a. Prefer to run on.
> b. Can run on.
> For alpha 4, we installed sun-java6-jre.
> It seems that gvsig requires java5.
> Will we run into conflicts if we install both java5 and java6?
> And I'm interested to know the impact on the final disk size also if we
> install both.
> As picked up by Jorge, each script should apt-get install <your version
> of java> as part of your script, to make sure that you have your
> dependencies installed.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAkquQsEACgkQ00HMccodrqXAZQCfYyeIiOK1sh2WYf3XIDxRMPK+
J8YAni+4RK4RqM0lH3Dw4J0G2M+bgZC6
=tHzw
-----END PGP SIGNATURE-----
More information about the Live-demo mailing list
