[Live-demo] Live DVD next release build starts in 12 hours - where are the docs?
Alex Mandel tech_dev at wildintellect.com
Wed Sep 16 22:04:09 EDT 2009
I think I know what's causing the "mleslie" role error. If Mark did a
dump from an existing database in the create table schema it
specifically includes the user that owns the database, we somehow need
to change that to the live disc user.
A quick hack would be to create the mleslie user before import.
sudo -u postgres createuser --superuser mleslie
Another option might be to do a scripted search and replace for the word
mleslie in the sql file with user.
sed 's/mleslie/user/g' filename.sql
At least that should work according to
Stefan Hansen wrote:
> Hey Mark!
> I tried to run your load_postgis.sh. Unfortunately, it didn't run through.
> Template_postgis does not exist. Should that be created in your
> load-script or in the postgres-install-script?
> After I created the template, your script complained that the role
> "mleslie" does not exist.
> cheers,
> stefan
> Mark Leslie wrote:
>> I've managed to commit a script load_postgis.sh to the repository.  It
>> runs on my debian machine, but none of the VM instances I was pointed to
>> are available to me, so I've been unable to test it in the VM.  If
>> someone has the chance, can you make sure it runs and add it to the
>> main.sh script?  As it stands, it won't get run during the build unless
>> this happens.
>> Mark
>> Cameron Shorter wrote:
>>> In 12 hours 8:30pm Thursday 17 Sept, I'll be starting the build process
>>> for the Live DVD's release candidate which we will be announcing widely
>>> and asking potential delegates to test.
>>> I'm concerned that at the moment, we only have docs for half the
>>> projects in:
>>> https://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/doc/descriptions
>>> (These docs are what users will see for the first time and will explain
>>> how to run the project)
>>> If anyone has some spare time to work on the Live DVD in the next 12
>>> hours could you please write docs for each of the projects, as per:
>>> http://wiki.osgeo.org/wiki/GISVM_Build#Writing_docs
>> Live-demo mailing list
>> Live-demo at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/live-demo
> Stefan Hansen
> Software Engineer
> LISAsoft
> Ph: +61 3 8680 3200 Fax: +61 3 8680 3299 Mob: +61
> Level 9, 601 Bourke St, Melbourne Vic 3000
> LISAsoft is part of the A2end Group of Companies
> http://www.ardec.com.au
> http://www.lisasoft.com
> http://www.terrapages.com
> The contents of this email are confidential and may be subject to legal
> or professional privilege and copyright. No representation is made that
> this email is free of viruses or other defects. If you have received
> this communication in error, you may not copy or distribute any part of
> it or otherwise disclose its contents to anyone. Please advise the
> sender of your incorrect receipt of this correspondence.
More information about the Live-demo mailing list
