[Live-demo] A folder for beta software
Cameron Shorter cameron.shorter at lisasoft.com
Tue Feb 2 05:46:00 EST 2010
On 2/02/2010 12:28 PM, Alex Mandel wrote:
> Juan Lucas Domínguez Rubio wrote:
>> Hello. Please have a look at this screenshot:
>> http://gvsigmobileonopenmoko.files.wordpress.com/2010/02/edit_menu.jpg
>> That's a Xubuntu 9.10 live CD with the applications menu slightly modified by adding some 10 lines to a certain XML file:
>> /etc/xdg/xubuntu/menus/xfce-applications.menu
>> I guess your Xubuntu 9.10 also has that XML in the same place. This additional line:
>> Categories: Beta;
>> has to be then written in the *.desktop files that are considered beta software, as I have done with that application called Tali.
>> If you are interested in this modification, I think I can help you write the script to do it automatically.
>> Regards,
>> Juan Lucas
> By all means please feel free to write a script that would do that.
> Either post it or add it as an optional section in the install_desktop.sh
> I think we passed on it last time because we didn't have enough time to
> work out a script to do the process. I did however research the solution
> and came to the same conclusion as you.
> Thanks,
> Alex
Yes Thanks Juan,
Adding Menus as you suggest would be great. Please go ahead and create it.
I suggest that we should set up a new category (on the same level as
Education) called "Geospatial"
So we would have:
Geospatial/gvsig
Geospatial/geoserver
Geospatial/beta/gvsig-mobile
Once you have worked out how it should be done, could you please also
update the build wiki so that others can follow your steps.
http://wiki.osgeo.org/wiki/GISVM_Build
Cameron Shorter
Geospatial Solutions Manager
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
