[Live-demo] Geopublisher sample project rw issue
Cameron Shorter cameron.shorter at gmail.com
Fri Feb 5 14:03:35 EST 2010
Stefan,
I like your suggestion of making /usr/local/share/geopublishing
read/writable, if it is possible to do this without increasing RAM usage.
However, I suspect that it will not work, as a LiveDVD would need to
store all read/write files in memory if it the base files system (the
DVD) is read only.
I suggest:
1. Use example data already packaged if you can.
2. Keep the data size small.
3. Experiment with setting the /usr/local directory to r/w, build an iso
from a VM and lets see what happens.
Stefan Krüger wrote:
> Hi
> I finally got the legal/data stuff cleared, and I am preparing a sample atlas
> for Geopublisher today that should also go in the DVD.  My idea is, that after
> starting Geopublisher, the open file dialog would automatically point to the
> demo atlas...
> I read at: http://wiki.osgeo.org/wiki/GISVM_Build, that sample data should go
> to /usr/local/share/... .
> But my demo atlas project folder must be "rw" by the user.
>> However, keep files in /home/user as small as possible as this folder is
> loaded into memory in the Live DVD. Symlinks into /usr/local can be useful
> here.
> No discussion: As it contains a few Mbs of data it would be a waste of memory
> to load the whole demo atlas always into memory. So it can't go into ~
> What other options do i have?
> * Is it possible to create  /usr/local/share/geopublishing and make it "o=rw"?
> Or is that non-sense on the DVD (some file systems can do this magic on
> readonly-devices)?
> Last Fallback option:
> I could always put the zipped demo atlas into /usr/local/share/geopublishing
> and explain in a README.TXT how to open it - but that is not as nice as being
> able to open it directly.
> Any other ideas?
Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
