[Live-demo] Little chaos in *_license.html files
Cameron Shorter cameron.shorter at gmail.com
Sun Feb 7 22:26:30 EST 2010
Juan Lucas Domínguez Rubio wrote:
> Dear list:
> I incidentally realized that there is a little chaos in  *_license.html files. If I got it right, each project only needs to add one or several:
> <tr>...</tr>
Correct.
> because those files will be concatenated, but some _license.html files are adding a whole <table>...</table>.
As you suggest, the <table> tags should be commented out.
> Also, I think we have to add three <td>...</td> inside each <tr>...</tr>, but some (for example, mine) are adding four because the previous version of the template had actually four.
Correct, there should only be 3 <td> tags now. (I removed the last one
after suggestion from Jody).
At the moment, the creation of a licence table is commented out in
install_main_docs.sh
You can uncomment these lines now if you like and test that it works.
> Regards,
> Juan Lucas
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
Cameron Shorter
Geospatial Solutions Manager
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
