[Live-demo] Little chaos in *_license.html files
Juan Lucas Domínguez Rubio
juan_lucas_dr at yahoo.com
Thu Feb 11 12:16:23 EST 2010
Also, make sure your files are called :
package_license.html
and not
package_licence.html
for the script says:
doc/descriptions/${ITEM}_license.html
Regards,
Juan Lucas
--- On Mon, 2/8/10, Cameron Shorter <cameron.shorter at gmail.com> wrote:
> From: Cameron Shorter <cameron.shorter at gmail.com>
> Subject: Re: [Live-demo] Little chaos in *_license.html files
> To: "Juan Lucas Domínguez Rubio" <juan_lucas_dr at yahoo.com>
> Cc: live-demo at lists.osgeo.org
> Date: Monday, February 8, 2010, 4:26 AM
> Juan Lucas Domínguez Rubio wrote:
> > Dear list:
> > I incidentally realized that there is a little chaos
> in *_license.html files. If I got it right, each
> project only needs to add one or several:
> > <tr>...</tr>
> Correct.
> > because those files will be concatenated, but some
> _license.html files are adding a whole
> <table>...</table>.
> As you suggest, the <table> tags should be commented
> out.
> > Also, I think we have to add three
> <td>...</td> inside each
> <tr>...</tr>, but some (for example, mine) are
> adding four because the previous version of the template had
> actually four.
> Correct, there should only be 3 <td> tags now. (I
> removed the last one after suggestion from Jody).
> At the moment, the creation of a licence table is commented
> out in install_main_docs.sh
> You can uncomment these lines now if you like and test that
> it works.
> > Regards,
> > Juan Lucas
> > Live-demo mailing list
> > Live-demo at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/live-demo
> -- Cameron Shorter
> Geospatial Solutions Manager
> Tel: +61 (0)2 8570 5050
> Mob: +61 (0)419 142 254
> Think Globally, Fix Locally
> Geospatial Solutions enhanced with Open Standards and Open
> Source
> http://www.lisasoft.com
More information about the Live-demo
