[Live-demo] [OSGeo] #532: VMware client Xorg unable to log in
OSGeo trac_osgeo at osgeo.org
Thu Feb 11 18:55:45 EST 2010
Reporter:  wildintellect       |       Owner:  live-demo at lists.osgeo.org
    Type:  defect              |      Status:  new
Priority:  normal              |   Component:  LiveDVD
Keywords:  desktop 3.0 VMWare  |
 On VMWare Server 2.x
 It does appear that using any kernel newer than the base kernel (might be
 related xorg package) on Xubuntu 9.10 causes an odd glitch where the login
 page comes up but X restarts after login and tosses you back out to the
 login page.
 Sometimes going into xterm session and running
 sudo dpkg-reconfigure xserver-xorg
 then exiting to restart X resolves the issue for a single login. Reading
 online hardcoding resolutions might also solve the issue with an xorg.conf
 file.(Note Xubuntu by default no longer has a xorg.conf file so you have
 to create it.)
 This issue does not effect !VirtualBox, might effect VMware player and is
 unlikely to effect the live DVD/USB.
 Should we temporarily disable the sudo apt-get dist-upgrade to exlude
 kernel updates?
 I also think we should modify the ubuntu config to only notify users about
 updates every 3-7 days. So that a normal person using it in a workshop
 will never see the update prompt.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/532>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
