[Live-demo] osgeo-live4.0alpha4 Virtual Machine ready for download
Cameron Shorter cameron.shorter at gmail.com
Mon Jun 21 00:48:25 EDT 2010
After a few hiccups, I've managed to complete building a Virtual Machine
for the OSGeoLive.
Logs of the build and the virtual machine can be downloaded from:
VirtualMachine:
http://downloads.lisasoft.com/live-4.0alpha4/live-4.0alpha4-vm.7z (~ 3 Gig)
MD5: http://downloads.lisasoft.com/live-4.0alpha4/live-4.0alpha4-vm.7z.md5
Logs: http://downloads.lisasoft.com/live-4.0alpha4/live-4.0alpha4-log.zip
Key notes:
* The Virtual Machine has been compressed with 7zip
* The Vitual Machine is a VirtualBox image. To run, install and run
VirtualBox, then select "Import Appliance" to select the virtual machine.
* I need to restart the build a couple of times (ran out of memory), and
in the process I lost logs for installing ~ 1/3 of the applications.
However, the application did install ok.
* Some scripts are installing their tmp files into the bin directory
instead of /tmp/build_XXX (spatiallite and mapguide in particular)
* There are lots of error logs associated with postgis data loads. Would
love to have someone look at those. I haven't had time to test or
analyse logs or applications more than that.
Cameron Shorter
Geospatial Solutions Manager
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
