[Live-demo] osgeo-live4.0alpha4 Virtual Machine ready for download
Alex Mandel tech_dev at wildintellect.com
Tue Jun 22 18:11:21 EDT 2010
On 06/20/2010 09:48 PM, Cameron Shorter wrote:
> After a few hiccups, I've managed to complete building a Virtual Machine
> for the OSGeoLive.
> Logs of the build and the virtual machine can be downloaded from:
> VirtualMachine:
> http://downloads.lisasoft.com/live-4.0alpha4/live-4.0alpha4-vm.7z (~ 3 Gig)
> MD5: http://downloads.lisasoft.com/live-4.0alpha4/live-4.0alpha4-vm.7z.md5
> Logs: http://downloads.lisasoft.com/live-4.0alpha4/live-4.0alpha4-log.zip
> Key notes:
> * The Virtual Machine has been compressed with 7zip
> * The Vitual Machine is a VirtualBox image. To run, install and run
> VirtualBox, then select "Import Appliance" to select the virtual machine.
> * I need to restart the build a couple of times (ran out of memory), and
> in the process I lost logs for installing ~ 1/3 of the applications.
> However, the application did install ok.
> * Some scripts are installing their tmp files into the bin directory
> instead of /tmp/build_XXX (spatiallite and mapguide in particular)
> * There are lots of error logs associated with postgis data loads. Would
> love to have someone look at those. I haven't had time to test or
> analyse logs or applications more than that.
Log file zip seems to be empty except for a folder, did I miss something?
I'm specifically working on postgis, pgrouting.
Thanks,
Alex
More information about the Live-demo mailing list
