[Live-demo] osgeo-live4.0alpha4 Virtual Machine ready for download
Cameron Shorter cameron.shorter at gmail.com
Tue Jun 22 18:20:15 EDT 2010
Alex, I'll have a look, but to get you started, the logs are on the VM,
in /var/logs/live/
On 23/06/10 08:11, Alex Mandel wrote:
> On 06/20/2010 09:48 PM, Cameron Shorter wrote:
>> After a few hiccups, I've managed to complete building a Virtual Machine
>> for the OSGeoLive.
>> Logs of the build and the virtual machine can be downloaded from:
>> VirtualMachine:
>> http://downloads.lisasoft.com/live-4.0alpha4/live-4.0alpha4-vm.7z (~ 3 Gig)
>> MD5: http://downloads.lisasoft.com/live-4.0alpha4/live-4.0alpha4-vm.7z.md5
>> Logs: http://downloads.lisasoft.com/live-4.0alpha4/live-4.0alpha4-log.zip
>> Key notes:
>> * The Virtual Machine has been compressed with 7zip
>> * The Vitual Machine is a VirtualBox image. To run, install and run
>> VirtualBox, then select "Import Appliance" to select the virtual machine.
>> * I need to restart the build a couple of times (ran out of memory), and
>> in the process I lost logs for installing ~ 1/3 of the applications.
>> However, the application did install ok.
>> * Some scripts are installing their tmp files into the bin directory
>> instead of /tmp/build_XXX (spatiallite and mapguide in particular)
>> * There are lots of error logs associated with postgis data loads. Would
>> love to have someone look at those. I haven't had time to test or
>> analyse logs or applications more than that.
> Log file zip seems to be empty except for a folder, did I miss something?
> I'm specifically working on postgis, pgrouting.
> Thanks,
> Alex
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Cameron Shorter
Geospatial Director
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
