[Live-demo] blue wombat desktop background
Hamish hamish_b at yahoo.com
Mon Mar 8 05:43:46 EST 2010
Hamish:
> > > It seems that someone finally overcame the deficiencies of the
> > > Mercator projection by wiping Greenland off the face of the
> > > Earth!
Alex:
> > Figures, this is what happens when you let a graphics
> > artist make a map
> > instead of a cartographer.
> > Tyler any chance we can get Greenland back, we'd probably be happy
> > to do it ourselves if we had a vector format file for that design.
Juan Lucas wrote:
> I've always thought that the size of Greenland in the
> Mercator projection was an obscenity, so well done, graphics
> artist!
> That being said, I don't care much about which projection
> is used in world maps, as long as Europe is kept in the
> middle ;-)
oi, careful.
well it's easy enough.
- take the etopo2 dataset,
- load it into a GRASS lat/lon location,
- set the resolution to 2 degrees,
- r.resamp.stats method=average to resample raster from original 2 arc-
   minutes to 2 degrees,
- raster -> vector points with r.to.vect,
- create a new winkel tripel location
- reproject the vector points into the winkel location with v.proj
- export as svg with v.out.svg.
and you get the attached..
2deg seems a bit crowded so here's 3,4,5 degrees too.
enjoy,
Hamish
Type: application/x-bzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/live-demo/attachments/20100308/35fe6a5d/etopo2_2deg_pos_winkelIII.svg-0001.bin
Desc: not available
Url : http://lists.osgeo.org/pipermail/live-demo/attachments/20100308/35fe6a5d/etopo2_3deg_pos_winkelIII.svg-0001.bin
Desc: not available
Url : http://lists.osgeo.org/pipermail/live-demo/attachments/20100308/35fe6a5d/etopo2_4deg_pos_winkelIII.svg-0001.bin
Desc: not available
Url : http://lists.osgeo.org/pipermail/live-demo/attachments/20100308/35fe6a5d/etopo2_5deg_pos_winkelIII.svg-0001.bin
More information about the Live-demo mailing list
