[Live-demo] Why is GeoNetwork throwing errors on LiveDVD?
Cameron Shorter cameron.shorter at lisasoft.com
Wed Mar 17 03:46:20 EDT 2010
GeoNetwork developers,
We are cutting the final version of the OSGeo Live DVD this Friday, and
GeoNetwork is the last application which is triggering errors.
Is there any chance someone could step forward and help our packages explain
and hopefully fix what is going on.
We are hanging out at irc://freenode.net#foss4g
Results of geonetwork tests are at:
http://wiki.osgeo.org/wiki/Live_GIS_Disc_Testing#geonetwork
 geonetwork Tests written for Geonetwork, LiveDVD 3.0 Test Description last
updated 14 March 2010 Steps
   - Click icon "Start Geonetwork" - wait until the server intializes (see
   load graph in the upper right hand corner)
   - open FireFox http://localhost:8880
   - you should see a list of active URLs, choose /geonetwork
Result
   - see the opening page of the Geonetwork server
   - Intermap is failing, it appears port reconfigure is correct but
   something else is off, going directly to intermap results in the following:
This XML file does not appear to have any style information associated
with it. The document tree is shown below.
<error id="error">
<message>
Found class com.sun.image.codec.jpeg.JPEGImageEncoder, but interface
was expected
</message>
<class>IncompatibleClassChangeError</class>
<stack>
<at class="org.wfp.vam.intermap.kernel.map.images.ImageMerger"
file="ImageMerger.java" line="185" method="encodeJPG"/>
file="ImageMerger.java" line="114" method="saveImage"/>
file="ImageMerger.java" line="82" method="mergeAndSave"/>
<at class="org.wfp.vam.intermap.kernel.map.MapMerger"
file="MapMerger.java" line="621" method="merge"/>
<at class="org.wfp.vam.intermap.services.map.Update"
file="Update.java" line="80" method="exec"/>
<at class="jeeves.server.dispatchers.ServiceInfo"
file="ServiceInfo.java" line="238" method="execService"/>
file="ServiceInfo.java" line="141" method="execServices"/>
<at class="jeeves.server.dispatchers.ServiceManager"
file="ServiceManager.java" line="377" method="dispatch"/>
<at class="jeeves.server.JeevesEngine" file="JeevesEngine.java"
line="621" method="dispatch"/>
<at class="jeeves.server.sources.http.JeevesServlet"
file="JeevesServlet.java" line="174" method="execute"/>
</stack>
<request>
<language>en</language>
<service>main</service>
</request>
</error>
Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Commercial Support for Geospatial Open Source Solutions
http://www.lisasoft.com/LISAsoft/SupportedProducts.html
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20100317/980aacff/attachment.html
More information about the Live-demo mailing list
