[Live-demo] Re: [GeoNetwork-devel] Why is GeoNetwork throwing errors on LiveDVD?
Cameron Shorter cameron.shorter at gmail.com
Wed Mar 17 16:01:50 EDT 2010
Thanks Heikki,
This does seem to be the case. Nice debugging work. Thank you very much
for the feedback.
user at user:~$ ps aux | grep java
user      2732 24.7 37.1 899576 189048 ?       Sl   04:54   0:46 java
-Xms48m -Xmx512m -Xss2M -XX:MaxPermSize=128m -DSTOP.PORT=8879
-Djava.awt.headless=true -DSTOP.KEY=geonetwork -jar start.jar
../bin/jetty.xml
user      2845  0.0  0.1   3040   804 pts/0    S+   04:57   0:00 grep
--color=auto java
user at user:~$ which java
/usr/bin/java
user at user:~$ java -version
java version "1.6.0_0"
OpenJDK Runtime Environment (IcedTea6 1.6.1) (6b16-1.6.1-3ubuntu1)
OpenJDK Client VM (build 14.0-b16, mixed mode, sharing)
Now what we need to do is update our geoserver install script [1] so
that it accesses the correct java version. We can probably do something
similar to the geoserver install script [2].
Is someone able to have a look at that?
[1]
https://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/bin/install_geoserver.sh
[2]
https://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/bin/install_geonetwork.sh
heikki wrote:
> hello,
> somehow I fail to connect to your IRC channel, so therefore this email.
> Could it be that you're using OpenJDK ? Is it possible to change to
> Sun's ? I think your error is related to that.. see for example
> http://codingexplorer.wordpress.com/2009/07/12/interface-was-expected-for-jpegimageencoder/.
> Kind regards
> Heikki Doeleman
> On Wed, Mar 17, 2010 at 8:46 AM, Cameron Shorter
> <cameron.shorter at lisasoft.com <mailto:cameron.shorter at lisasoft.com>>
> wrote:
>     GeoNetwork developers,
>     We are cutting the final version of the OSGeo Live DVD this
>     Friday, and GeoNetwork is the last application which is triggering
>     errors.
>     Is there any chance someone could step forward and help our
>     packages explain and hopefully fix what is going on.
>     We are hanging out at irc://freenode.net#foss4g
>     <http://freenode.net#foss4g>
>     Results of geonetwork tests are at:
>     http://wiki.osgeo.org/wiki/Live_GIS_Disc_Testing#geonetwork
>       geonetwork
>     Tests written for
>         Geonetwork, LiveDVD 3.0
>     Test Description last updated
>         14 March 2010
>     Steps
>         * Click icon "Start Geonetwork" - wait until the server
>           intializes (see load graph in the upper right hand corner)
>         * open FireFox http://localhost:8880 <http://localhost:8880/>
>         * you should see a list of active URLs, choose /geonetwork
>     Result
>         * see the opening page of the Geonetwork server
>         * Intermap is failing, it appears port reconfigure is correct
>           but something else is off, going directly to intermap
>           results in the following:
>     This XML file does not appear to have any style information associated with it. The document tree is shown below.
>>     <error id="error">
>>     <message>
>     Found class com.sun.image.codec.jpeg.JPEGImageEncoder, but interface was expected
>     </message>
>     <class>IncompatibleClassChangeError</class>
>>     <stack>
>     <at class="org.wfp.vam.intermap.kernel.map.images.ImageMerger" file="ImageMerger.java" line="185" method="encodeJPG"/>
>     <at class="org.wfp.vam.intermap.kernel.map.images.ImageMerger" file="ImageMerger.java" line="114" method="saveImage"/>
>     <at class="org.wfp.vam.intermap.kernel.map.images.ImageMerger" file="ImageMerger.java" line="82" method="mergeAndSave"/>
>     <at class="org.wfp.vam.intermap.kernel.map.MapMerger" file="MapMerger.java" line="621" method="merge"/>
>     <at class="org.wfp.vam.intermap.services.map.Update" file="Update.java" line="80" method="exec"/>
>     <at class="jeeves.server.dispatchers.ServiceInfo" file="ServiceInfo.java" line="238" method="execService"/>
>     <at class="jeeves.server.dispatchers.ServiceInfo" file="ServiceInfo.java" line="141" method="execServices"/>
>     <at class="jeeves.server.dispatchers.ServiceManager" file="ServiceManager.java" line="377" method="dispatch"/>
>     <at class="jeeves.server.JeevesEngine" file="JeevesEngine.java" line="621" method="dispatch"/>
>     <at class="jeeves.server.sources.http.JeevesServlet" file="JeevesServlet.java" line="174" method="execute"/>
>     </stack>
>>     <request>
>     <language>en</language>
>     <service>main</service>
>     </request>
>     </error>
>     Cameron Shorter
>     Geospatial Systems Architect
>     Tel: +61 (0)2 8570 5050
>     Mob: +61 (0)419 142 254
>     Think Globally, Fix Locally
>     Commercial Support for Geospatial Open Source Solutions
>     http://www.lisasoft.com/LISAsoft/SupportedProducts.html
>     Download Intel&#174; Parallel Studio Eval
>     Try the new software tools for yourself. Speed compiling, find bugs
>     proactively, and fine-tune applications for parallel performance.
>     See why Intel Parallel Studio got high marks during beta.
>     http://p.sf.net/sfu/intel-sw-dev
>     _______________________________________________
>     GeoNetwork-devel mailing list
>     GeoNetwork-devel at lists.sourceforge.net
>     <mailto:GeoNetwork-devel at lists.sourceforge.net>
>     https://lists.sourceforge.net/lists/listinfo/geonetwork-devel
>     GeoNetwork OpenSource is maintained at
>     http://sourceforge.net/projects/geonetwork
> GeoNetwork OpenSource is maintained at http://sourceforge.net/projects/geonetwork
Cameron Shorter
Geospatial Solutions enhanced with Open Standards and Open Source
More information about the Live-demo mailing list
