[Live-demo] Re: Why is GeoNetwork throwing errors on LiveDVD?
Alex Mandel tech_dev at wildintellect.com
Wed Mar 17 21:24:45 EDT 2010
Brian Hamlin wrote:
> with a tiny bit of investigation, it looks like someone with java
> knowledge needs to set
> $JAVA_OPTS  to include  --XXaltjvm=/usr/lib/jvm/java-6-sun-1.6.0.15
> something
> in the launch script...
> this DVD is likely to get a lot of exposure..
> I would argue its worth the time of someone to make this small change
> best regards
>   -Brian
> Brian Hamlin
> planetwork.net
> OSGeo California Chapter
> (415) 717-4462 cell
Just needed to give it the path to the java it wants instead of calling
straight java which picks the system default. If this causes problems
for lots of packages we can consider running update-alternatives to set
sun java as the default.
Fixed in revision, 3421
Thanks,
Alex
More information about the Live-demo mailing list
