[Live-demo] Re: Why is GeoNetwork throwing errors on LiveDVD?
Judit Mays mays at lat-lon.de
Thu Mar 18 02:49:03 EDT 2010
Alex Mandel schrieb:
> Brian Hamlin wrote:
>> with a tiny bit of investigation, it looks like someone with java
>> knowledge needs to set
>> $JAVA_OPTS  to include  --XXaltjvm=/usr/lib/jvm/java-6-sun-1.6.0.15
>> something
>> in the launch script...
>> this DVD is likely to get a lot of exposure..
>> I would argue its worth the time of someone to make this small change
>> best regards
>>   -Brian
>> Brian Hamlin
>> planetwork.net
>> OSGeo California Chapter
>> (415) 717-4462 cell
> Just needed to give it the path to the java it wants instead of calling
> straight java which picks the system default. If this causes problems
> for lots of packages we can consider running update-alternatives to set
> sun java as the default.
> Fixed in revision, 3421
> Thanks,
> Alex
I remember we already had a discussion about Java version before the 2.0
release. deegree also needs sun-java, and there were other projects as
well. So I favour to dump openJDK and get Sun-Java in versions 1.5 and
1.6 onto the DVD by default.
Kind regards,
Judit
Desc: OpenPGP digital signature
Url : http://lists.osgeo.org/pipermail/live-demo/attachments/20100318/0466d54f/signature.bin
More information about the Live-demo mailing list
