[Live-demo] Re: Why is GeoNetwork throwing errors on LiveDVD?
Cameron Shorter cameron.shorter at gmail.com
Thu Mar 18 14:57:29 EDT 2010
Judit Mays wrote:
> Alex Mandel schrieb:
>> Brian Hamlin wrote:
>>> with a tiny bit of investigation, it looks like someone with java
>>> knowledge needs to set
>>> $JAVA_OPTS  to include  --XXaltjvm=/usr/lib/jvm/java-6-sun-1.6.0.15
>>> something
>>> in the launch script...
>>> this DVD is likely to get a lot of exposure..
>>> I would argue its worth the time of someone to make this small change
>>> best regards
>>>   -Brian
>>> Brian Hamlin
>>> planetwork.net
>>> OSGeo California Chapter
>>> (415) 717-4462 cell
>> Just needed to give it the path to the java it wants instead of calling
>> straight java which picks the system default. If this causes problems
>> for lots of packages we can consider running update-alternatives to set
>> sun java as the default.
>> Fixed in revision, 3421
>> Thanks,
>> Alex
> Hi,
> I remember we already had a discussion about Java version before the 2.0
> release. deegree also needs sun-java, and there were other projects as
> well. So I favour to dump openJDK and get Sun-Java in versions 1.5 and
> 1.6 onto the DVD by default.
> Kind regards,
> Judit
Yes Judit,
Lets re-open this discussion after we release the final 3.0 at the end
of this week.
And we can pick a common java version for all. (I'd also like to look
into common datasets, and other common installs too, like tomcat)
Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
