[Live-demo] Re: Prune in the OSGeoLive DVD?
activityworkshop mail at activityworkshop.net
Sat Oct 9 14:45:28 EDT 2010
Cameron Shorter wrote:
> Thank you - lots of people have spent a lot of time on it. It is nice
> to hear positive feedback.
It shows, it looks like a great publicity tool.
I noticed quite a few typos in the docs though, I'll have a go at fixing
some of them after I've jumped through the administrative hoops :)
> I'd be interested to understand the differences between Viking and
> Prune and understand reasons why people will choose one over the other.
Good question.  I don't want to diss Viking but personally I find Prune
simpler and easier to use.  Prune doesn't have a "layers" panel with
lots of options, it just shows tracks on top of a map.  So you don't
have problems like the following (from the Viking docs):
"You will notice the maps are being drawn on top of the tracks, which is
probably not what you want."
Prune tries to be simple and intuitive to use, although obviously you
then don't get the more powerful options of Viking like multiple layers
and sublayers and so on.
Also from what I understand Viking can't correlate photos with gps
tracks, but instead relies on calling the gpsphoto app separately and
then loading just the coordinates saved by gpsphoto into Viking.  With
Prune you load the jpegs directly, see the photos, do the correlation,
save the coordinates into the exif tags of the photos, export thumbnails
of the photos into kmz files and so on all from within the same application.
Similarly, Viking seems only able to load and save gpx files, whereas
Prune can load txt, csv, kml, kmz, nmea and gpx files and can save all
of those formats too (apart from nmea).  Plus Prune has 3d abilities
that Viking doesn't, and runs on OSX too.
In summary, I'd say (imho) Viking tries to be a powerful multi-layer GIS
application, whereas Prune tries to be easy to use and concentrates on
what (I think) the bulk of non-power-users want to be able to do.
> I'm wary of the OSGeo-Live disk promoting every possible application,
> as it will just confuse new users.
I agree, and I won't be offended if you say that Prune won't make it
onto the dvd :)
> How much RAM does it use, and how much disk space (assuming java is
> already installed).
I've not done detailed memory usage tests, but I've run it perfectly
fine on a low-RAM machine using a live CD.  The jar file itself is
around 700 kB and the only other requirement is a JVM (sun-java6 is
perfect).  Although as I said if gpsbabel is there too, then Prune can
use it to get tracks directly out of a GPS receiver).
> I'm interested to understand the stability of Prune and the community
> behind it.
> You might want to use this page as an idea for talking points in
> answering this question:
> http://www.osgeo.org/incubator/process/project_graduation_checklist.html
Ok, so those requirements sound perhaps a little too demanding for Prune
at the moment.
( ObPedant: s/achieved/archived/ and s/Marketting/Marketing/ )
There isn't currently a governance policy, or project management
committee, or management processes, or a Project Management Plan.  It
does have an issue tracker, patch submission and public communications
(at sourceforge) but no automated test system.  And the release process
isn't really "defined" as such, it just has releases every three or four
months, announced about a month in advance with a call for translators
(currently 12 languages are well supported by various volunteers).
Feature requests are submitted by email or in the sourceforge forums,
and open to discussion.  Releases occur on a "when ready" basis, after a
feature-freeze and text-freeze.
As for popularity / how widely deployed it is, I don't have precise
numbers but my download stats tells me there is steadily growing
interest (since birth in 2006).  However, Debian's popcon tells me there
are a lot fewer installs of Prune than of Viking; hopefully this will
change once Prune gets into Debian stable.  Prune also runs on Windows
and OSX and is also available as an rpm for OpenSuse.
Anyway, even if Prune doesn't make it onto the DVD, it still may be of
interest to some of you guys.  In particular, suggestions of ways in
which it can fit together with other projects are very welcome.  For
example, the proposal for Prune to also do audio file correlation for
openstreetmap contributors recording their own notes is currently being
worked on and will come with the next release.
More information about the Live-demo mailing list
