[Live-demo] Re: Calling for OSGeo-Live Testers
Frank Gasdorf
fgdrf at users.sourceforge.net
Tue Aug 2 07:54:24 EDT 2011
few minutes ago I added myself to the list (udig) and added "Natural Earth"
to column "Uses common dataset?".
If successfully done I guess I should change the filed -color from yellow to
green (QuickStart status), shouldn't I?
But with the beta1 build I had some trouble with the Firefox installation.
Alex, could you check ticket https://trac.osgeo.org/osgeo/ticket/742 I believe
something changed between alpha and beta builds ...
Started beta3 download and will try it later...
Cheers, Frank
2011/8/2 Cameron Shorter <cameron.shorter at gmail.com>
> Frank,
> I wonder whether you will be able to help with the UAT?
> Do you have enough bandwidth to download a VM?
> -------- Original Message -------- Subject: Calling for OSGeo-Live
> Testers Date: Tue, 02 Aug 2011 21:15:26 +1000 From: Cameron Shorter
> <cameron.shorter at gmail.com> <cameron.shorter at gmail.com> To:
> live-demo at lists.osgeo.org <live-demo at lists.osgeo.org><live-demo at lists.osgeo.org>
> Apart from a couple of exceptions, I believe we have the final versions
> of all 49 osgeo-live applications installed on OSGeo-Live, and for the
> next 2 weeks, we will be in the User Acceptance Test phase of OSGeo-Live.
> What we are looking for is a number of testers who can download the
> latest Virtual Machine from http://live.osgeo.org/dev/build/ then
> support projects by testing applications and making sure they work.
> Once tested, please update the "Tested By" column in our status sheet: https://spreadsheets.google.com/ccc?key=0Al9zh8DjmU_RdGIzd0VLLTBpQVJuNVlHMlBWSDhKLXc&hl=en_GB#gid=8
> This helps us keep track or what works or doesn't.
> Raise any issues you find in our issue tracker and/or email list and/or IRC.
> We are hanging out on irc://freenode.net#osgeolive
> Cameron Shorter
> Geospatial Director
> Tel: +61 (0)2 8570 5050
> Mob: +61 (0)419 142 254
> Think Globally, Fix Locally
> Geospatial Solutions enhanced with Open Standards and Open Sourcehttp://www.lisasoft.com
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20110802/dd0a532c/attachment.html
More information about the Live-demo
