[Live-demo] Re: Calling for OSGeo-Live Testers
Cameron Shorter cameron.shorter at gmail.com
Tue Aug 2 16:29:24 EDT 2011
Frank,
For Quickstarts to be considered reviewed, we would be looking for
someone to review the text against the template and writing guidelines.
Based on my experience of reviewing all Project Overviews, I'd expect
that every Quickstart will have numerous updates to do as part of the
review. I was hoping to review Quickstarts for this release, but instead
focused on addressing licensing issues. Hopefully we can review all
Quickstarts for the next release.
But in short, I'm not expecting any Quickstart to be at the 5.0Final
status for this release.
On 02/08/11 21:54, Frank Gasdorf wrote:
> few minutes ago I added myself to the list (udig) and added "Natural
> Earth" to column "Uses common dataset?".
> If successfully done I guess I should change the filed -color from
> yellow to green (QuickStart status), shouldn't I?
> But with the beta1 build I had some trouble with the Firefox
> installation.
> Alex, could you check ticket
> https://trac.osgeo.org/osgeo/ticket/742 I believe something changed
> between alpha and beta builds ...
> Started beta3 download and will try it later...
> Cheers, Frank
> 2011/8/2 Cameron Shorter <cameron.shorter at gmail.com
> <mailto:cameron.shorter at gmail.com>>
>     Frank,
>     I wonder whether you will be able to help with the UAT?
>     Do you have enough bandwidth to download a VM?
>     -------- Original Message --------
>     Subject: 	Calling for OSGeo-Live Testers
>     Date: 	Tue, 02 Aug 2011 21:15:26 +1000
>     From: 	Cameron Shorter <cameron.shorter at gmail.com>
>     To: 	live-demo at lists.osgeo.org <mailto:live-demo at lists.osgeo.org>
>     <live-demo at lists.osgeo.org> <mailto:live-demo at lists.osgeo.org>
>     Apart from a couple of exceptions, I believe we have the final versions
>     of all 49 osgeo-live applications installed on OSGeo-Live, and for the
>     next 2 weeks, we will be in the User Acceptance Test phase of OSGeo-Live.
>     What we are looking for is a number of testers who can download the
>     latest Virtual Machine fromhttp://live.osgeo.org/dev/build/  then
>     support projects by testing applications and making sure they work.
>     Once tested, please update the "Tested By" column in our status sheet:
>     https://spreadsheets.google.com/ccc?key=0Al9zh8DjmU_RdGIzd0VLLTBpQVJuNVlHMlBWSDhKLXc&hl=en_GB#gid=8  <https://spreadsheets.google.com/ccc?key=0Al9zh8DjmU_RdGIzd0VLLTBpQVJuNVlHMlBWSDhKLXc&hl=en_GB#gid=8>
>     This helps us keep track or what works or doesn't.
>     Raise any issues you find in our issue tracker and/or email list and/or IRC.
>     We are hanging out onirc://freenode.net#osgeolive
>     Cameron Shorter
>     Geospatial Director
>     Tel: +61 (0)2 8570 5050
>     Mob: +61 (0)419 142 254
>     Think Globally, Fix Locally
>     Geospatial Solutions enhanced with Open Standards and Open Source
>     http://www.lisasoft.com
Cameron Shorter
Geospatial Director
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20110803/ee818628/attachment-0001.html
More information about the Live-demo mailing list
