[Live-demo] Can we remove OpenJDK from OSGeo-Live?
Jorge Gaspar Sanz Salinas
jsanz at osgeo.org
Wed Aug 10 01:08:30 EDT 2011
On 9 August 2011 22:59, Cameron Shorter <cameron.shorter at gmail.com> wrote:
> OSGeo-LIve project contacts,
> We are trying to find space on OSGeoLive, and expect that we can remove
> OpenJDK, the free java implementation, as most applications seem to be using
> the Sun JRE instead.
> So from the java projects:
> * Will you application be able to run without OpenJDK? (It seems that
> rasdaman is the only application drawing it in)
> * Will your application run with only Sun's JRE or do you require JDK as
> well?
Cameron, list
The gvSIG Desktop package of the OSGeo Live works fine with Sun or
OpenJDK versions of the Java Runtime (no need of JDK) so even when we
would love to work with the free software VM, it's ok for gvSIG to
work with the Sun/Oracle version.
Best regards
Jorge Sanz
http://es.osgeo.org
More information about the Live-demo
