[Live-demo] Can we remove OpenJDK from OSGeo-Live?
Eike Hinderk Jürrens
e.h.juerrens at 52north.org
Wed Aug 10 01:41:44 EDT 2011
In behalf of 52nSOS:
Am 09.08.2011 22:59, schrieb Cameron Shorter:
> OSGeo-LIve project contacts,
> We are trying to find space on OSGeoLive, and expect that we can
> remove OpenJDK, the free java implementation, as most applications
> seem to be using the Sun JRE instead.
> So from the java projects:
> * Will you application be able to run without OpenJDK? (It seems that
> rasdaman is the only application drawing it in)
YES
> * Will your application run with only Sun's JRE or do you require JDK
> as well?
It requires tomcat => Sun's JRE should be enough.
Kind regards,
Eike
52° North Initiative for Geospatial Open Source Software GmbH
Martin-Luther-King-Weg 24
48155 Münster, Germany
E-Mail: e.h.juerrens at 52north.org
Fon: +49-(0)-251–396371-33
Fax: +49-(0)-251–396371-11
http://52north.org/
General Managers: Dr. Albert Remke, Dr. Andreas Wytzisk
Local Court Muenster HRB 10849
More information about the Live-demo
