[Live-demo] OSSIM not working on live 4.5
Eduardo Kanegae
eduardo.kanegae at gmail.com
Wed Aug 10 07:26:32 EDT 2011
Will be the upgrade to next DVD (>4.5) possible without loosing user data?
Eduardo
On 08/09/2011 08:35 PM, Massimo Di Stefano wrote:
> i'm going to build it again
> ... anyway the last time (more or less 2 weeks ago) that i tried the .iso it worked fine, that's weird ...
> i'll post something about in the next h.
> --massimo.
> Il giorno 10/ago/2011, alle ore 00.43, Hamish ha scritto:
>> [sorry for top-posting]
>> Hi,
>> the ossim package fails to install because the install script
>> wants libgdal 1.7.0, but only 1.6.0 and 1.8.0 are available.
>> (ubuntu 11.04 natty + ubuntugis's PPA)
>> I have just modified the script to bail out if the package
>> dependencies fail to install, but if this doesn't get fixed
>> very soon it isn't going to ship. :-(
>> there may or may not be other problems, but the above is an
>> obvious one.
>> see the build logs for details
>> http://live.osgeo.org/dev/build/
>> thanks,
>> Hamish
>> Eduardo wrote:
>>> hi there,
>>> just to report: with the same DVD I used with my notebook,
>>> I installed a common desktop machine and ossim command line
>>> tools is running fine on that.
>>> If is there any trick that I can do for debugging purposes,
>>> feel free to tell me.
>>> regards
>>> *Eduardo Patto Kanegae*
>>> http://www.webmapit.com
>>> -------- Original Message --------
>>> From: Cameron Shorter
>>> Massimo,
>>> I'm not sure if you have seen this error report from
>>> Eduardo for OSSIM?
>>> On 27/07/11 23:20, Eduardo Kanegae wrote:
>>>> Hi,
>>>> First of all, I found DVD live very nice. It's a very kind solution
>>>> for those who are looking for a simple solution of 'how to build a
>>>> Linux GIS workstation in 20minutes'.
>>>> I already had tested most of instaled GIS applications, including
>>>> visual/gui interfaces of OSSIM packages but OSSIM command line tools
>>>> it's not working. Eg.
>>>> $ ossim-create-histo myimage1.tif
>>>> says:
>>>> ossim-create-histo: symbol lookup error:
>>> ossim-create-histo: undefined
>>>> symbol:
>>> _ZNK25ossimImageHandlerRegistry4openERK13ossimFilename
>>>> and
>>>> $ ossim-info myimage2.tif
>>>> says:
>>>> symbol:
>>>> Last info: I'm not using the 'user' account. I've created a new
>>>> account for me.
>>>> thanks in advance
More information about the Live-demo
