[Live-demo] OSSIM not working on live 4.5
Alex Mandel tech_dev at wildintellect.com
Wed Aug 10 13:14:14 EDT 2011
If you have OSGeo Live installed, then that is a whole different story.
You can probably use the install_ossim.sh script from our repo to just
upgrade ossim on your existing installation.
OSGeo Live itself is not a distro, so we don't support upgrading from
one OSGeo Live to the next. If you want to do upgrades that's all
regular ubuntu stuff, meaning a user would use the ubuntu package
manager to update the underlying system and then use our scripts or
ubuntugis repos to keep their GIS software up to date.
Thanks,
Alex
On 08/10/2011 04:26 AM, Eduardo Kanegae wrote:
> Will be the upgrade to next DVD (>4.5) possible without loosing user data?
> Eduardo
> On 08/09/2011 08:35 PM, Massimo Di Stefano wrote:
>> i'm going to build it again
>> ... anyway the last time (more or less 2 weeks ago) that i tried the
>> .iso it worked fine, that's weird ...
>> i'll post something about in the next h.
>> --massimo.
>> Il giorno 10/ago/2011, alle ore 00.43, Hamish ha scritto:
>>> [sorry for top-posting]
>>> Hi,
>>> the ossim package fails to install because the install script
>>> wants libgdal 1.7.0, but only 1.6.0 and 1.8.0 are available.
>>> (ubuntu 11.04 natty + ubuntugis's PPA)
>>> I have just modified the script to bail out if the package
>>> dependencies fail to install, but if this doesn't get fixed
>>> very soon it isn't going to ship. :-(
>>> there may or may not be other problems, but the above is an
>>> obvious one.
>>> see the build logs for details
>>>   http://live.osgeo.org/dev/build/
>>> thanks,
>>> Hamish
>>> Eduardo wrote:
>>>> hi there,
>>>> just to report: with the same DVD I used with my notebook,
>>>> I installed a common desktop machine and ossim command line
>>>> tools is running fine on that.
>>>> If is there any trick that I can do for debugging purposes,
>>>> feel free to tell me.
>>>> regards
>>>> *Eduardo Patto Kanegae*
>>>> http://www.webmapit.com
>>>> -------- Original Message --------
>>>> From:     Cameron Shorter
>>>> Massimo,
>>>> I'm not sure if you have seen this error report from
>>>> Eduardo for OSSIM?
>>>> On 27/07/11 23:20, Eduardo Kanegae wrote:
>>>>>    Hi,
>>>>>    First of all, I found DVD live very nice. It's a very kind solution
>>>>>    for those who are looking for a simple solution of 'how to build a
>>>>>    Linux GIS workstation in 20minutes'.
>>>>>    I already had tested most of instaled GIS applications, including
>>>>>    visual/gui interfaces of OSSIM packages but OSSIM command line
>>>>> tools
>>>>>    it's not working. Eg.
>>>>>    $ ossim-create-histo myimage1.tif
>>>>>    says:
>>>>>    ossim-create-histo: symbol lookup error:
>>>> ossim-create-histo: undefined
>>>>>    symbol:
>>>> _ZNK25ossimImageHandlerRegistry4openERK13ossimFilename
>>>>>    and
>>>>>    $ ossim-info myimage2.tif
>>>>>    says:
>>>>>    symbol:
>>>>>    Last info: I'm not using the 'user' account. I've created a new
>>>>>    account for me.
>>>>>    thanks in advance
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
More information about the Live-demo mailing list
