[Live-demo] Re: Questions about rasdaman, Java and OSGeo-Live
Cameron Shorter cameron.shorter at gmail.com
Wed Aug 10 08:21:37 EDT 2011
On 10/08/11 19:34, Michael Owonibi wrote:
> Hi Cameron,
> I tried out the custom install for our system, and it works well. So,
> I do not foresee any problem with the custom install.
Thanks Michael,
I assume this means that rasdaman must work with sun JVM?
> Thanks
> On 10 August 2011 03:18, <cameron.shorter at gmail.com
> <mailto:cameron.shorter at gmail.com>> wrote:
>     Peter,Michael,
>     Would you mind responding to this email on behalf of: rasdaman
>     On 10/08/11 09:28, Jody Garnett wrote:
>         Cameron if you were able to ensure the Sun JRE used included
>         JAI / ImageIO / ImageIO-Ext then the udig project could make
>         use of it directly (rather than using its own JRE as is done
>         currently). An easy way to check would be to use the bundled
>         JRE from the udig install script (rather than the sun jre) and
>         see all the applications still work.
>         The procedure to make one of these JRE+Extensions is here:
>         http://udig.refractions.net/confluence/display/ADMIN/JRE+for+Linux
>         - I can ask on udig-devel if they have made a script for this
>         one yet.
>         Jody
>     OSGeo-Live Java people,
>     Does Jody's suggestion make sense for your project?
>     Do you expect your project would work using UDig's custom java
>     install?
>     Would you anticipate we might run into any stability issues?
>     Will this proposal help your project save any space?
>     Any other thoughts?
>     Please CC responses to live-demo at lists.osgeo.org
>     <mailto:live-demo at lists.osgeo.org>
>     Cameron Shorter
>     Geospatial Director
>     Tel: +61 (0)2 8570 5050 <tel:%2B61%20%280%292%208570%205050>
>     Mob: +61 (0)419 142 254 <tel:%2B61%20%280%29419%20142%20254>
>     Think Globally, Fix Locally
>     Geospatial Solutions enhanced with Open Standards and Open Source
>     http://www.lisasoft.com
> Michael Owonibi, Ph.D. Student
> Jacobs University Bremen
> School of Engineering and Science
> College Ring 1, 28759 Bremen
> +49 421 200-3050
Cameron Shorter
Geospatial Director
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20110810/7899f182/attachment.html
More information about the Live-demo mailing list
