[Live-demo] Re: Questions about rasdaman, Java and OSGeo-Live
Michael Owonibi m.owonibi at jacobs-university.de
Wed Aug 10 09:07:16 EDT 2011
Yes.
Thanks
On 10 August 2011 14:21, Cameron Shorter <cameron.shorter at gmail.com> wrote:
> On 10/08/11 19:34, Michael Owonibi wrote:
> Hi Cameron,
> I tried out the custom install for our system, and it works well. So, I do
> not foresee any problem with the custom install.
> Thanks Michael,
> I assume this means that rasdaman must work with sun JVM?
> Thanks
> On 10 August 2011 03:18, <cameron.shorter at gmail.com> wrote:
>> Peter,Michael,
>> Would you mind responding to this email on behalf of: rasdaman
>> On 10/08/11 09:28, Jody Garnett wrote:
>>> Cameron if you were able to ensure the Sun JRE used included JAI /
>>> ImageIO / ImageIO-Ext then the udig project could make use of it directly
>>> (rather than using its own JRE as is done currently). An easy way to check
>>> would be to use the bundled JRE from the udig install script (rather than
>>> the sun jre) and see all the applications still work.
>>  The procedure to make one of these JRE+Extensions is here:
>>> http://udig.refractions.net/confluence/display/ADMIN/JRE+for+Linux - I
>>> can ask on udig-devel if they have made a script for this one yet.
>>  Jody
>> OSGeo-Live Java people,
>> Does Jody's suggestion make sense for your project?
>> Do you expect your project would work using UDig's custom java install?
>> Would you anticipate we might run into any stability issues?
>> Will this proposal help your project save any space?
>> Any other thoughts?
>> Please CC responses to live-demo at lists.osgeo.org
>> Cameron Shorter
>> Geospatial Director
>> Tel: +61 (0)2 8570 5050
>> Mob: +61 (0)419 142 254
>> Think Globally, Fix Locally
>> Geospatial Solutions enhanced with Open Standards and Open Source
>> http://www.lisasoft.com
> Michael Owonibi, Ph.D. Student
> Jacobs University Bremen
> School of Engineering and Science
> College Ring 1, 28759 Bremen
> +49 421 200-3050
> Cameron Shorter
> Geospatial Director
> Geospatial Solutions enhanced with Open Standards and Open Sourcehttp://www.lisasoft.com
+49 421 200-3050
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20110810/244e6743/attachment.html
More information about the Live-demo mailing list
