[Live-demo] Re: Can we remove OpenJDK from OSGeo-Live?
Cameron Shorter cameron.shorter at gmail.com
Wed Aug 10 16:19:08 EDT 2011
Thanks activityworkshop,
I've CCed your comments to the live-list, for the benefit of the other
java developers.
On 11/08/11 04:05, activityworkshop wrote:
> Hi Cameron,
> Yes you're right, I haven't been able to read all the list emails lately.
> In answer to your question, yes Prune will run fine with Sun's JRE, in
> fact that's the one I usually use (although OpenJDK is also ok).
> On 10/08/11 01:03, Cameron Shorter wrote:
>> In case you missed this on the live email list ...
>> On 10/08/11 06:59, Cameron Shorter wrote:
>>> OSGeo-LIve project contacts,
>>> We are trying to find space on OSGeoLive, and expect that we can
>>> remove OpenJDK, the free java implementation, as most applications
>>> seem to be using the Sun JRE instead.
>>> So from the java projects:
>>> * Will you application be able to run without OpenJDK? (It seems
>>> that rasdaman is the only application drawing it in)
>>> * Will your application run with only Sun's JRE or do you require
>>> JDK as well?
Cameron Shorter
Geospatial Director
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
