[Live-demo] Re: [OSGeo] #754: GeoMajas doesn't work on first click
OSGeo
trac_osgeo at osgeo.org
Wed Aug 24 21:06:03 EDT 2011
Reporter: camerons | Owner: live-demo@…
Type: defect | Status: new
Priority: critical | Milestone:
Component: LiveDVD | Keywords: 5.0, geomajas
Comment(by hamish):
Replying to [comment:3 camerons]:
> Located the issue down to the startup script, which is downloaded as
part of geomajas:
> user at user:~$ /usr/local/bin/start_geomajas.sh
> awk: {print int(0.5+100*\$1/\$2)}
> awk: ^ backslash not last character on line
> failed to create drawable
> user at user:~$
> Offending code is coming from the introduced delay clause:
> DELAY=40
> for TIME in \`seq \$DELAY\` ; do
> sleep 1
> echo "\$TIME \$DELAY" | awk '{print int(0.5+100*\$1/\$2)}'
> done
> ) | zenity --progress --auto-close --text "Loading Geomajas"
right, the '\' were in there as part of the
cat << EOF > start.sh
code in the other install scripts, which need backticks and $ chars to the
quoted. The 7 `\` in that script should be removed.
the script comes in from the upstream installer package, so must be fixed
in the http://files.geomajas.org/release/geomajas-$GEOMAJAS_VERSION-
bin.zip file.
thanks,
Hamish
ps- put code within `{{{`, `}}}` to stop trac from trying to interpret it
as markup.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/754#comment:5>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
