[Live-demo] Re: [OSGeo] #754: GeoMajas doesn't work on first click
OSGeo trac_osgeo at osgeo.org
Thu Aug 25 02:58:31 EDT 2011
 Reporter:  camerons  |       Owner:  live-demo@…
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:
Component:  LiveDVD   |    Keywords:  5.0, geomajas
Comment(by hamish):
 5.0rc3 iso booted in qemu/kVM:
 removing the 7 '\' from start_geomajas.sh corrects the startup timer
 problems, but when firefox does come up you get an "Unable to connect" ...
 "can't establish a connection to localhost:3420". url is
 `http://localhost:3420/showcase/`.
 running start_geomajas.sh from a terminal prompt I see the following two
 failed to create drawtable
 (firefox-bin:3973): GnomeUI-WARNING **: While connecting to session
 manager:
  Authentication Rejected, reason : None of the authentication protocols
  specified are supported and host-based authentication failed.
 ?? Maybe those are important, maybe not.
 I'm not sure if it works on the 5.0rc3 VM or not; still downloading that.
 ah. I think I see the problem--
 the older timer that was commented out also included the startup!
 need to add
  /usr/lib/geomajas-1.8.0-bin/bin/startup.sh &
 on a line before `DELAY=40` in the /usr/local/bin/geomajas_startup.sh
 script.
 that startup script comes from upstream not our build scripts, so we've
 got to wait for upstream to fix it.
 Hamish
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/754#comment:6>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
