[Live-demo] Install into Virtual Box doesn't pick up on options
Cameron Shorter cameron.shorter at gmail.com
Fri Jan 21 22:15:25 EST 2011
Hi Graham,
I think I've reproduced the problem, of sorts.
I tried installing into a VM from the ISO, using a different username
and password as you suggest below.
Like you, I've found that the user/pass defaults to "user"/"user" rather
than the user/pass I assigned it.
(I selected a keyboard type = English, and that was picked up correctly).
As a work around, I suggest that you either create a new user (using
"useradd" from the command line), or set a new password for the default
user (using "passwd" from the commandline).
On 21/01/11 11:48, Brian Hamlin wrote:
> Hi Graham-
>   its hard to pin down a problem without sitting right at your setup
> One possibility is that if you wrote down the exact and complete
> series of steps you took
> a tester could try to duplicate the problem..
>   Other than that, since you were able to start the installed machine
> you can use standard practice to add a user and change the keyboard
>   best regards from California
>    -Brian
> Brian Hamlin
> planetwork.net
> OSGeo california Chapter
> (415) 717-4462 cell
> On Jan 20, 2011, at 11:10 AM, Graham Smith wrote:
>> Hello,
>> I have just installed OSGEO Live 4.0 in to Virtual Box 3.2.12 on
>> Ubuntu 10.10.
>> During the install, I entered my user name and password as well as
>> setting up a UK keyboard and language,  But after the install
>> language and keyboard were set for US and password and user name were
>> both set to user user.
>> I have red the intro about passwords, but is the install meant to
>> ignore the options when permanently installing, rather than running
>> as a live CD.
>> Thanks,
>> Graham
>> Live-demo mailing list
>> Live-demo at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/live-demo
>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Cameron Shorter
Geospatial Director
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
