[Live-demo] OSGeo-Live 5.0 Feature Freeze in one week, 4 July 2011
Cameron Shorter cameron.shorter at gmail.com
Sun Jun 26 19:14:09 EDT 2011
OSGeo-Live Developers,
If you have not already done so, could you please ensure that your
install scripts are up to date by 4 July 2011 (in one week).
The scripts should be installing onto Ubuntu 11.04 and should use the
version of software which will be distributed at FOSS4G. This is an
alpha milestone, so an occasional bug is ok.
Below are links to logs from our last build, along with some analysis
which may help you.
On 26/06/11 14:55, Hamish wrote:
> Alex wrote:
>> http://live.osgeo.org/dev/build/5alpha2-log.tar.gz
>> Went a little better than last time. I had to manually
>> interrupt and restart it (though not clean) somewhere towards
>> the end of Java stuff.
> thanks,
>> Opps sorry I didn't up the version on the alpha build (I
>> always forget that each new cycle).
> semi-bumped now. a build-checklist.txt in svn might help ..
>> If the logs look decent after a day I'll go ahead and pack
>> a vm for people to download to make future testing of scripts
>> easier on the 5.0 version.
> still propagating packaging errors in this one leaving the
> system in a broken state...
> 5.0a2 quick build log review:
> everyone:
> ${CURLY} brackets do nothing to protect the command line from
> spaces and special chars within variables. Use "double quotes"
> for that.
> geoserver:
> FIXME: 'export FOO=bar' is a Bashism and will not work with Ubuntu's #!/bin/sh  (which is dash)
> geomajas:
> GeoMajas FIXME: Do not use 777 if at all possible.
> geonetwork:
> any way to make your 250mb package smaller?
> deegree, openjump, maptiler:
> FIXME: don't use wget for local files, just copy from local svn checkout:  cp ../app-conf/$FILE $DEST
> gvSIG:
>> mv: cannot stat `gvSIG19_new_features.tar.gz': No such file or directory
> etc.
> osm:
> temporary DNS trouble, now fixed?
> Static copy of Denver.osm.bz2 now stashed on OSGeo download server, note
> many times bigger than Barcelona, which may make the PostGIS DB
> huge?
> Sahaha:
> a number of errors, e.g.:
>> DataError: value too long for type character varying(64)
>> OSError: [Errno 13] Permission denied: 'applications/eden/compiled'
> Ushahidi:
>> ... Ushahidi already downloaded
>> tar: A lone zero block at 17095
> (probably want to do a timestamp check with the wget, but -N and -O are
> mutually exclusive)
>> ERROR 1045 (28000): Access denied for user 'root'@'localhost'
> there is no root password. try operating as another user name.
> geopublisher, atlasstyler:
>> E: Package 'geopublishing-doc' has no installation candidate
> mapfish:
>> Download error: [Errno -2] Name or service not known -- Some packages may not be found!
> script is very verbose, making it hard to pick out real error
> messages.
> mapguide:
> .debs need to be updated for Ubuntu 11.04, ie to not depend on odbcinst1debian1
> Uses a disproportionate amount of disc space (>375mb). please
> find ways to slim it down.
> [after this all other deb installs are broken for the rest of the ISO build..]
> ossim:
> wants libgdal1-1.7.0, but only 1.6.0 and 1.8.0 are available.
> ->  rebuild for natty
> WARNING: wget -N timestamping does nothing in combination with -O.
> 52nSOS:
> please shut off pgsql verbose mode&  fix errors, if possible.
> otb:
> fails-- no packages for ubuntu/natty found in PPA.
> [after this even less of the apt system works...]
> disc space:
> can we safely uninstall linux-headers-2.6.38-8? (81.5mb)
> + linux-headers-2.6.38-8-generic (10mb)
> (is building the proprietary nvidia driver a critical need?)
> Hamish
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Cameron Shorter
Geospatial Director
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
