[Live-demo] 5.0alpha2 build logs
Manuel Grizonnet manuel.grizonnet at gmail.com
Mon Jun 27 03:03:25 EDT 2011
concerning otb, the library is in the release candidate process. The release
3.10 is planned for the 06/30. I hope that Ubuntu Natty packages will be
available just after that (orfeotoolbox-nightly packages already work on
Natty : https://launchpad.net/~otb/+archive/orfeotoolbox-nightly).
I'll send more informations at the end of the week.
Regards,
Manuel
2011/6/26 Hamish <hamish_b at yahoo.com>
> Alex wrote:
> > http://live.osgeo.org/dev/build/5alpha2-log.tar.gz
> > Went a little better than last time. I had to manually
> > interrupt and restart it (though not clean) somewhere towards
> > the end of Java stuff.
> thanks,
> > Opps sorry I didn't up the version on the alpha build (I
> > always forget that each new cycle).
> semi-bumped now. a build-checklist.txt in svn might help ..
> > If the logs look decent after a day I'll go ahead and pack
> > a vm for people to download to make future testing of scripts
> > easier on the 5.0 version.
> still propagating packaging errors in this one leaving the
> system in a broken state...
> 5.0a2 quick build log review:
> everyone:
> ${CURLY} brackets do nothing to protect the command line from
> spaces and special chars within variables. Use "double quotes"
> for that.
> geoserver:
> FIXME: 'export FOO=bar' is a Bashism and will not work with Ubuntu's
> #!/bin/sh  (which is dash)
> geomajas:
> GeoMajas FIXME: Do not use 777 if at all possible.
> geonetwork:
> any way to make your 250mb package smaller?
> deegree, openjump, maptiler:
> FIXME: don't use wget for local files, just copy from local svn checkout:
>  cp ../app-conf/$FILE $DEST
> gvSIG:
> > mv: cannot stat `gvSIG19_new_features.tar.gz': No such file or directory
> etc.
> osm:
> temporary DNS trouble, now fixed?
> Static copy of Denver.osm.bz2 now stashed on OSGeo download server, note
> many times bigger than Barcelona, which may make the PostGIS DB
> huge?
> Sahaha:
> a number of errors, e.g.:
> > DataError: value too long for type character varying(64)
> > OSError: [Errno 13] Permission denied: 'applications/eden/compiled'
> Ushahidi:
> > ... Ushahidi already downloaded
> > tar: A lone zero block at 17095
> (probably want to do a timestamp check with the wget, but -N and -O are
> mutually exclusive)
> > ERROR 1045 (28000): Access denied for user 'root'@'localhost'
> there is no root password. try operating as another user name.
> geopublisher, atlasstyler:
> > E: Package 'geopublishing-doc' has no installation candidate
> mapfish:
> > Download error: [Errno -2] Name or service not known -- Some packages may
> not be found!
> script is very verbose, making it hard to pick out real error
> messages.
> mapguide:
> .debs need to be updated for Ubuntu 11.04, ie to not depend on
> odbcinst1debian1
> Uses a disproportionate amount of disc space (>375mb). please
> find ways to slim it down.
> [after this all other deb installs are broken for the rest of the ISO
> build..]
> ossim:
> wants libgdal1-1.7.0, but only 1.6.0 and 1.8.0 are available.
> -> rebuild for natty
> WARNING: wget -N timestamping does nothing in combination with -O.
> 52nSOS:
> please shut off pgsql verbose mode & fix errors, if possible.
> otb:
> fails-- no packages for ubuntu/natty found in PPA.
> [after this even less of the apt system works...]
> disc space:
> can we safely uninstall linux-headers-2.6.38-8? (81.5mb)
> + linux-headers-2.6.38-8-generic (10mb)
> (is building the proprietary nvidia driver a critical need?)
> Hamish
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Manuel
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20110627/e244c175/attachment-0001.html
More information about the Live-demo mailing list
