[Live-demo] LiveDVD 4.5b2 - Geomajas 1.8.0
Angelos Tzotsos gcpp.kalxas at gmail.com
Wed Mar 9 08:22:46 EST 2011
Ok, the fix worked fine and is in trunk.
Sorry Pieter for the inconvenience.
Thank you for your time.
Angelos
On 03/09/2011 03:06 PM, Angelos Tzotsos wrote:
> Hi,
> I managed to find the issue, it is permissions in the webapps directory.
> I will create a fix, test it and let you know about the results.
> Regards,
> Angelos
> On 03/09/2011 02:32 PM, Pieter De Graef wrote:
>> Hmm,
>> this is a problem. I don't see any errors in the logs. It seems as if
>> everything booted correctly. As for the JSP error, thats not an
>> actual error, but information from the Jetty container saying that it
>> will not support JSP files. This is not a problem since Geomajas does
>> not use any JSP files.
>> See here: http://wiki.eclipse.org/Jetty/FAQ#JSP_support_not_configured.3F
>> So...I'm downloading the LiveDvd right now. I'll try and boot it up
>> later (download takes a while).
>> I was also thinking... the first time I installed Geomajas on the
>> LiveDVD there a simple timing issue that made it seem as if Geomajas
>> was not correctly installed. It started FireFox while Geomajas was
>> still starting up, and so gave an error message. Have you tried
>> waiting a bit longer and than visiting the URL in firefox?
>> 2011/3/9 Angelos Tzotsos <gcpp.kalxas at gmail.com
>> <mailto:gcpp.kalxas at gmail.com>>
>>     Hi Pieter,
>>     The problem is on startup. I am sending you the startup log.
>>     There is a message about "No JSP support for /showcase".
>>     GeoMajas seems to install, there are startup links on the desktop.
>>     When we do a build, we start almost from scratch, we just have a
>>     preinstalled Xubuntu virtual machine ready with updates.
>>     The installation logs are here:
>>     http://osprey.ucdavis.edu/downloads/osgeo/gisvm/latest/4.5beta3-log.tar.gz
>>     The virtual machine is here:
>>     http://osprey.ucdavis.edu/downloads/osgeo/gisvm/latest/OSGeoLive-v4.5beta3.7z
>>     or mirrored here:
>>     http://aiolos.survey.ntua.gr/gisvm/dev/OSGeoLive-v4.5beta3.7z
>>     Thanks for your help,
>>     Regards,
>>     Angelos
>>     On 03/09/2011 09:30 AM, Pieter De Graef wrote:
>>>     I'm sorry I haven't been in touch the last couple of days. I've
>>>     been working behind a pretty secure firewall, and can't event
>>>     SSH to the outside world...
>>>     Where exactly does it go wrong? Is Geomajas downloaded
>>>     successfully? Is it a problem during startup?
>>>     If it is a problem during startup, could you send me the Tomcat
>>>     logs?
>>>     Also, when you guys do a build, do you always start from
>>>     scratch? I noticed that in the install script it checks whether
>>>     or not Geomajas has already been downloaded, but I recently had
>>>     to make a change to the download package, so perhaps the new one
>>>     wasn't used...
>>>     PS: Is there still that virtualbox url somewhere so I can see
>>>     for myself?
>>>         Hi Peter,
>>>         It seems that GeoMajas does not work in version 4.5 beta3:
>>>         http://trac.osgeo.org/osgeo/ticket/675
>>>         Can you please advise?
>>>         Regards,
>>>         Angelos
>>>         On 02/28/2011 01:10 PM, Pieter De Graef wrote:
>>>             Update:
>>>             There was indeed a problem starting the Jetty web
>>>             container. This should be solved now.
>>>             On 02/28/2011 08:14 AM, Pieter De Graef wrote:
>>>                 Brian,
>>>                 I will look into it asap.
>>>                 On 02/26/2011 12:04 PM, Brian Hamlin wrote:
>>>                     Geomajas Team Representatives -
>>>                      testing the build on the latest LiveDVD, I ran
>>>                     into a number of permission problems with the
>>>                     install, as I understand it..
>>>                     Although i checked in several small changes to
>>>                     the install script, I still see the following error
>>>                      $ /usr/lib/geomajas-1.8.0-bin/bin/startup.sh
>>>                      INFO::NO JSP Support for /Showcase, did not
>>>                     find org.apache.lasper.servlet.JspServlet
>>>                     and an error is shown when browsing to
>>>                     localhost:3420/showcase/
>>>                      please confirm this as soon as possible, thanks
>>>                       -Brian
>>>                     Brian Hamlin
>>>                     planetwork.net <http://planetwork.net>
>>>                     OSGeo California Chapter
>>>                     (415) 717-4462 cell
>>>                     _______________________________________________
>>>                     Live-demo mailing list
>>>                     Live-demo at lists.osgeo.org
>>>                     <mailto:Live-demo at lists.osgeo.org>
>>>                     http://lists.osgeo.org/mailman/listinfo/live-demo
>>>                     http://wiki.osgeo.org/wiki/Live_GIS_Disc
>>>         Angelos Tzotsos
>>>         Remote Sensing Laboratory
>>>         National Technical University of Athens
>>>         http://users.ntua.gr/tzotsos
>>     Angelos Tzotsos
> Angelos Tzotsos
Angelos Tzotsos
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20110309/d284b2d6/attachment-0001.html
More information about the Live-demo mailing list
