[Live-demo] Build RC3 Status
Cameron Shorter cameron.shorter at gmail.com
Thu Mar 17 17:54:43 EDT 2011
Eike,
For the record, can you please clearly confirm the current status of
what will be delivered on the upcoming osgeo-live 4.5. If I understand
you correctly, there will be errors in the build logs, but the
application will work fine?
On 17/03/11 20:49, Eike Hinderk Jürrens wrote:
> Hi Cameron, dear others.
> Am 16.03.2011 20:46, schrieb Cameron Shorter:
>>>    52nSOS shows build errors in the log - can someone with knowledge
>>> of the 52 North products look into this ?
>> I've emailed Eike Hinderk Jürrens<e.h.juerrens at 52north.org>  asking
>> him to investigate.
> The "problem" is, that I took as source for the demo SOS a database
> which is running for some years and uses an older version of PostGIS.
> As for the other RCs, the 52°North SOS is running good and responds as
> required to the requests by the test client.
> For OSGEO-LiveDVD, I am planning to update the database.
> > From my side, this is not a problem now but you are welcome for
> correcting me.
> Kind regards,
> Eike
Cameron Shorter
Geospatial Director
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
