[Live-demo] Build RC3 Status
Eike Hinderk Jürrens e.h.juerrens at 52north.org
Fri Mar 18 09:39:09 EDT 2011
Hi Cameron!
Am 17.03.2011 22:54, schrieb Cameron Shorter:
> For the record, can you please clearly confirm the current status of
what will be delivered on the upcoming osgeo-live 4.5.
> If I understand you correctly, there will be errors in the build logs,
but the application will work fine?
Yes, you understand me correctly. I tested the server is with the
predefined requests from our test client.
Does this answer your question?
Service is working.
Test client is working.
Install script is working but contains some errors as explained in
previous messages of this thread.
Documentation is available in EN and DE.
Kind regards,
Eike
52° North Initiative for Geospatial Open Source Software GmbH
Martin-Luther-King-Weg 24
48155 Münster, Germany
E-Mail: e.h.juerrens at 52north.org
Fon: +49-(0)-251–396371-33
Fax: +49-(0)-251–396371-11
http://52north.org/
General Managers: Dr. Albert Remke, Dr. Andreas Wytzisk
Local Court Muenster HRB 10849
More information about the Live-demo mailing list
