[Live-demo] GEOS image for OSGeo-Live Overview
Cameron Shorter cameron.shorter at gmail.com
Wed Apr 4 06:56:11 EDT 2012
Martin,
In that case, I'd suggest that JTS is a likely candidate for OSGeo-Live.
Next steps, if you wish to progress is to check to see what is involved
from your part, and if you want to progress, then send a request to have
JTS join osgeo-live, as per:
http://wiki.osgeo.org/wiki/Live_GIS_Disc_Apply
On 4/04/2012 8:03 AM, Martin Davis wrote:
> JTS does have a user interface, the TestBuilder.  It lets you create,
> edit, inspect and process geometries using the JTS algorithms.
> Martin
> On Tue, Apr 3, 2012 at 1:21 PM, Cameron Shorter
> <cameron.shorter at gmail.com <mailto:cameron.shorter at gmail.com>> wrote:
>     Martin,
>     Our criteria and checklist for bringing a project into OSGeo-Live
>     are linked from here:
>     http://wiki.osgeo.org/wiki/Live_GIS_Disc#How_to_add_a_project_to_OSGeoLive
>     We include applications which can be installed and run, and also
>     include descriptions of libraries from OSGeo incubated/incubating
>     projects.
>     So I see the key criteria for including JTS would be:
>     1. Does it have a user interface?
>     2. Or otherwise, is it an OSGeo project?
>     Others from our team may wish to add further comment or suggestion
>     to this.
>     On 02/04/12 09:40, Martin Davis wrote:
>>     Cameron,
>>     I'm fine with using that image (or image idea) for the GEOS image.
>>     I don't have a larger version - it would have to be recreated.
>>     This would be fairly easy to do using the JTS TestBuilder, which
>>     can export to PNG.  But I won't have time to do that until after
>>     FOSS4G - I"m pretty busy beforehand!
>>     Are the questions about JTS at OSGeo and on OSGeo-Live two
>>     separate questions?  8^)  I did have a short discussion with
>>     Frank in Denver about bringing JTS into OSGeo.  I think he was
>>     concerned that it could not meet the acceptance criteria, such as
>>     having a wider developer community.  But if it can be included on
>>     OSGeo-Live in spite of that, I'm happy for that to happen.
>>     HTH - Martin
>>     On Sun, Apr 1, 2012 at 1:38 PM, Cameron Shorter
>>         On 02/04/12 04:02, Frank Warmerdam wrote:
>>                 Frank, do you have suggestions for a GEOS image?
>>             Possibly something like this:
>>             http://tsusiatsoftware.net/jts/images/example-intersection.gif
>>             But that is already used for JTS so it might be a cop-out
>>             to grab it.
>>         Martin,
>>         I suspect that you would have been the original creator of
>>         the image Frank references above?
>>         Do you have any objection to it being used in conjunction
>>         with GEOS?
>>         Maybe we could have 2 variants on the same image, one for
>>         JTS, the other for GEOS?
>>         Do you have a larger version of the image? It needs to be
>>         1024x768 for osgeo docs.
>>         This does lead to a later question, about bringing JTS into
>>         OSGeo and OSGeo-Live. (We aim to include descriptions of all
>>         OSGeo library projects on OSGeo-Live.)
>>         Cameron Shorter
>>         Geospatial Solutions Manager
>>         Tel: +61 (0)2 8570 5050 <tel:%2B61%20%280%292%208570%205050>
>>         Mob: +61 (0)419 142 254 <tel:%2B61%20%280%29419%20142%20254>
>>         Think Globally, Fix Locally
>>         Geospatial Solutions enhanced with Open Standards and Open Source
>>         http://www.lisasoft.com
>     Cameron Shorter
>     Tel:+61 (0)2 8570 5050  <tel:%2B61%20%280%292%208570%205050>
>     Mob:+61 (0)419 142 254  <tel:%2B61%20%280%29419%20142%20254>
Cameron Shorter
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20120404/ab1dc2c2/attachment.html
More information about the Live-demo mailing list
