[Live-demo] What version of applications should we be installing on OSGeo-Live 6.5? - for osm
Cameron Shorter cameron.shorter at gmail.com
Wed Dec 5 14:54:36 PST 2012
Javi,
I suspect Alex might be able to help answer this question.
I wouldn't be surprised if gdebi is installed by some applications, then
uninstalled.
I'm not in a linux environment at the moment, but you might want to grep
for gdebi in the bin directory to see if it is used by other apps.
On 6/12/2012 9:47 AM, Javi Sanchez wrote:
> Hi,
> running install_osm.sh script in a new updated ubuntu 12.04 VM, I find
> the following problem when the script tries to install gosmore:
>     ./gosmore_install.sh: 8: ./gosmore_install.sh: gdebi: not found
> Does it make sense to add a comand in advance to install gdebi (
> apt-get install --assume-yes gdebi )?
> On the other hand, I have completed gosmore installation manually, but
> I don't know how to find out which version of Gosmore I am running.
> The rest seems to be ok, but I have to check more things...
> Thanks in advance for any help. Am I still on time with this issue?
> Regards,
> Javi Sánchez.
Cameron Shorter
Geospatial Solutions Manager
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20121206/a4ce9c1e/attachment.html>
More information about the Live-demo mailing list
