[Live-demo] What version of applications should we be installing on OSGeo-Live 6.5? - for osm
Alex Mandel tech_dev at wildintellect.com
Fri Dec 7 13:30:03 PST 2012
Isn't gdebi a graphical tool? I believe the command line equivalent
would be dpkg -i
Thanks,
Alex
On 12/05/2012 02:54 PM, Cameron Shorter wrote:
> Javi,
> I suspect Alex might be able to help answer this question.
> I wouldn't be surprised if gdebi is installed by some applications, then
> uninstalled.
> I'm not in a linux environment at the moment, but you might want to grep
> for gdebi in the bin directory to see if it is used by other apps.
> On 6/12/2012 9:47 AM, Javi Sanchez wrote:
>> Hi,
>> running install_osm.sh script in a new updated ubuntu 12.04 VM, I find
>> the following problem when the script tries to install gosmore:
>>     ./gosmore_install.sh: 8: ./gosmore_install.sh: gdebi: not found
>> Does it make sense to add a comand in advance to install gdebi (
>> apt-get install --assume-yes gdebi )?
>> On the other hand, I have completed gosmore installation manually, but
>> I don't know how to find out which version of Gosmore I am running.
>> The rest seems to be ok, but I have to check more things...
>> Thanks in advance for any help. Am I still on time with this issue?
>> Regards,
>> Javi Sánchez.
More information about the Live-demo mailing list
