[Live-demo] OpenJUMP and OpenJDK
Michaël Michaud michael.michaud at free.fr
Mon Jan 2 15:27:38 EST 2012
Hi Cameron,
Hopefully, OpenJUMP 1.5 will be ready by the end of the week.
Several users report problems for OpenJUMP + OpenJDK 1.6 embedded in
Ubuntu 11.04 (see below).
These problems are solved with OpenJDK1.7 though.
Can you confirm that the osgeo-live-dvd will switch to OpenJDK 1.7, not
1.6 ?
Thanks,
Michaël
On 02.01.2012 10:20, Giuseppe Aruta wrote:
>  Hi all,
>  this is my experience with OJ and JRE.
>  Some months ago I tested the same bug with OpenJDK 1.6 which is embedded in Ubuntu 11.04.
>  This bug was always present with all tools that were involving parts of the features "outside" the view, plus "Draw constrained circle" tool.
>  I did some tests with other JRE distro. This problem seems not to be present also with JRE 1.6.20 (coming from Kosmo which has jre embedded) from Sun Microsystem (previous Oracle "management").
>  I did other tests with newer version of Oracle JRE/OpenJDK.
>  The problem seems not to be with JRE 1.7 from Oracle neither with  OpenJDK 1.7.
>  So I installed on my Ubuntu OpenJDK 1.7 and everything goes fine right now.
>  I ask Ede and Matthias to check wich version of JRE they use with OpenJUMP
>  Peppe
>  *Da:* Stefan Steiniger<sstein at geo.uzh.ch>
>  *A:* OpenJump develop and use<jump-pilot-devel at lists.sourceforge.net>
>  *Inviato:* Domenica 1 Gennaio 2012 22:30
>  *Oggetto:* Re: [JPP-Devel] OJ Linux GUI bug?
>  no problem on Mac here :)
>  Am 01.01.12 22:24, schrieb Edgar Soldin:
>>  On 01.01.2012 21:53, Matthias Scholz wrote:
>>>  Hi,
>>>  on Linux it seems to be, that we have a problem. It's possible, that this is a JVM on Linux bug by Oracle. On Windows this problem does not occurs. Please see the attached screenshots. This mistake occurs, if you move a feature and some parts of the feature are "outside" the OJ window(viewport). The first screenshot is taken after move of the rectangle with pressed mousebutton and the second is taken after release the left mouse button. Can anyone test this with Linux?
>>  can you specify linux and jre version please? ..ede
>>  Ridiculously easy VDI. With Citrix VDI-in-a-Box, you don't need a complex
>>  infrastructure or vast IT resources to deliver seamless, secure access to
>>  virtual desktops. With this all-in-one solution, easily deploy virtual
>>  desktops for less than the cost of PCs and save 60% on VDI infrastructure
>>  costs. Try it free! http://p.sf.net/sfu/Citrix-VDIinabox
>>  _______________________________________________
>>  Jump-pilot-devel mailing list
>>  Jump-pilot-devel at lists.sourceforge.net<mailto:Jump-pilot-devel at lists.sourceforge.net>
>>  https://lists.sourceforge.net/lists/listinfo/jump-pilot-devel
More information about the Live-demo mailing list
