[Live-demo] OpenJUMP and OpenJDK
Brian Hamlin maplabs at light42.com
Mon Jan 2 15:57:37 EST 2012
On Jan 2, 2012, at 12:27 PM, Michaël Michaud wrote:
> Hi Cameron,
> Hopefully, OpenJUMP 1.5 will be ready by the end of the week.
> Several users report problems for OpenJUMP + OpenJDK 1.6 embedded
> in Ubuntu 11.04 (see below).
> These problems are solved with OpenJDK1.7 though.
> Can you confirm that the osgeo-live-dvd will switch to OpenJDK 1.7,
> not 1.6 ?
> Thanks,
> Michaël
If jumping to OpenJDK is as large a step as it seems, then why would
it be desirable to use anything but the latest stable OpenJDK ?
the subtleties of this page are lost on me, the unsophisticated observer
     http://openjdk.java.net/projects/jdk7u/qanda.html
> On 02.01.2012 10:20, Giuseppe Aruta wrote:
>>  Hi all,
>>  this is my experience with OJ and JRE.
>>  Some months ago I tested the same bug with OpenJDK 1.6 which is
>> embedded in Ubuntu 11.04.
>>  This bug was always present with all tools that were involving
>> parts of the features "outside" the view, plus "Draw constrained
>> circle" tool.
>>  I did some tests with other JRE distro. This problem seems not to
>> be present also with JRE 1.6.20 (coming from Kosmo which has jre
>> embedded) from Sun Microsystem (previous Oracle "management").
>>  I did other tests with newer version of Oracle JRE/OpenJDK.
>>  The problem seems not to be with JRE 1.7 from Oracle neither
>> with  OpenJDK 1.7.
>>  So I installed on my Ubuntu OpenJDK 1.7 and everything goes fine
>> right now.
>>  I ask Ede and Matthias to check wich version of JRE they use with
>> OpenJUMP
>>  Peppe
>>  *Da:* Stefan Steiniger<sstein at geo.uzh.ch>
>>  *A:* OpenJump develop and use<jump-pilot-
>> devel at lists.sourceforge.net>
>>  *Inviato:* Domenica 1 Gennaio 2012 22:30
>>  *Oggetto:* Re: [JPP-Devel] OJ Linux GUI bug?
>>  no problem on Mac here :)
>>  Am 01.01.12 22:24, schrieb Edgar Soldin:
>>>  On 01.01.2012 21:53, Matthias Scholz wrote:
>>>>  Hi,
>>>>  on Linux it seems to be, that we have a problem. It's possible,
>>>> that this is a JVM on Linux bug by Oracle. On Windows this
>>>> problem does not occurs. Please see the attached screenshots.
>>>> This mistake occurs, if you move a feature and some parts of the
>>>> feature are "outside" the OJ window(viewport). The first
>>>> screenshot is taken after move of the rectangle with pressed
>>>> mousebutton and the second is taken after release the left mouse
>>>> button. Can anyone test this with Linux?
>>>  can you specify linux and jre version please? ..ede
>>>  Ridiculously easy VDI. With Citrix VDI-in-a-Box, you don't need
>>> a complex
>>>  infrastructure or vast IT resources to deliver seamless, secure
>>> access to
>>>  virtual desktops. With this all-in-one solution, easily deploy
>>> virtual
>>>  desktops for less than the cost of PCs and save 60% on VDI
>>> infrastructure
>>>  costs. Try it free! http://p.sf.net/sfu/Citrix-VDIinabox
>>>  _______________________________________________
>>>  Jump-pilot-devel mailing list
>>>  Jump-pilot-devel at lists.sourceforge.net<mailto:Jump-pilot-
>>>  https://lists.sourceforge.net/lists/listinfo/jump-pilot-devel
>>  Ridiculously easy VDI. With Citrix VDI-in-a-Box, you don't need a
>> complex
>> access to
>> virtual
>> infrastructure
>> complex
>> access to
>> virtual
>> infrastructure
> complex
> access to
> virtual desktops. With this all-in-one solution, easily deploy virtual
> infrastructure
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://live.osgeo.org
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
More information about the Live-demo mailing list
