[Live-demo] Access to Trac and Subversion
Ramirez, Paul M (398J) paul.m.ramirez at jpl.nasa.gov
Thu Jun 13 11:57:48 PDT 2013
Hi all,
I'd like to contribute a VM Depot version of OSGeo-Live. Could I please get access to Trac and subversion so I can enter the issue. My osgeo-user id is: pramirez.
Here is the issue I was hoping to add:
Summary: OSGeoLive VM Depot Documentation
Description:
VM Depot [1] is a place to host community based VMs that can then be spun up onto Microsoft Azure. Once the VM is hosted on VM Depot the documentation will guide end users on how to start up the VM. From there all the other OSGeoLive documentation should follow.
The first step is to merely test out deploying the VM onto VM Depot and then spinning it up on Azure. After some discussion on the mailing list this process should be fairly straight forward as OSGeoLive is already built as a VM. Any success here would guide doing the same on Amazon. If there are changes to the VM then a separate task will be initiated to track any changes for the VM.
[1] http://vmdepot.msopentech.com/
Type: Task
Priority: Normal
Milestone: OSGeoLive7.0
Component: WebSite
Keywords: vm vmdepot azure cloud
Assign to: pramirez
Thanks,
Paul Ramirez
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20130613/f236a8af/attachment.html>
More information about the Live-demo mailing list
