[Live-demo] pywps to osgeo-live
Jachym Cepicky
jachym.cepicky at gmail.com
Mon Aug 4 03:28:19 PDT 2014
Maybe simple OpenLayers2-based applicaton could do buffer.
It should be working with QGIS-WPS plugin too, but, since the
standard is relatively underspecified in some fields, there might be a
problem.
Thanks
Jachym
2014-08-04 12:17 GMT+02:00 Jorge Sanz <jsanz at osgeo.org>:
> 2014-08-04 11:49 GMT+02:00 Jachym Cepicky <jachym.cepicky at gmail.com>:
>> Cameron
>> I disagree in most of your points.
>> Use case for PyWPS is the same as ZOO or 52North. If it is established
>> and stable, I can not tell - community has to tell.
>> PyWPS is simple and focused application. Maybe we do not have web
>> interface, but we know, where our position is
>> I have no time for this. I've forwarded it to pywps-dev list, maybe
>> someone else will pick this issue.
>> Cheers
>> Jachym
> Hi Jachym
> I think here the problem is maybe a too "pythonic" quickstart without
> any reference to a client interface.
> Is it possible to call one of the sample processes using any of the
> OSGeo Live interfaces? This way the user has something to play with
> and if interested, can be curious enough to try to modify the python
> code. Maybe it's just a matter of having a simple OpenLayers or
> Leaflet viewer that calls a process et voilà.
> Hope it helps.
> Jorge Sanz
> http://www.osgeo.org
> http://wiki.osgeo.org/wiki/Jorge_Sanz
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/pgp/JachymCepicky.pgp
Give your code freedom with PyWPS - http://pywps.wald.intevation.org
More information about the Live-demo
