[Live-demo] pywps to osgeo-live
Edwards, Ian ian.edwards at metoffice.gov.uk
Mon Aug 4 03:38:57 PDT 2014
RE: PyWPS..
I need to improve the Iris quickstart (Iris doesn't have a GUI either)
I could easily adapted our OL2 tutorial from FOSS4G 2013 to work with PyWPS
  https://github.com/SciTools/osgeolive/tree/master/docs/osgeolive/source/solutions/zoo_rolling_window
  https://github.com/SciTools/osgeolive/blob/master/docs/osgeolive/source/foss4g_2013/advanced_wps_iris.rst
This would then give a demo of PyWPS, and the initial demo process would make just make use of "import iris" to read data from an unusual GIS data file (e.g. NetCDF).
-----Original Message-----
From: live-demo-bounces at lists.osgeo.org [mailto:live-demo-bounces at lists.osgeo.org] On Behalf Of Jachym Cepicky
Sent: 04 August 2014 11:28
To: Jorge Sanz
Cc: live-demo at lists.osgeo.org
Subject: Re: [Live-demo] pywps to osgeo-live
Maybe simple OpenLayers2-based applicaton could do buffer.
 It should be working with QGIS-WPS plugin too, but, since the standard is relatively underspecified in some fields, there might be a problem.
Thanks
Jachym
2014-08-04 12:17 GMT+02:00 Jorge Sanz <jsanz at osgeo.org>:
> 2014-08-04 11:49 GMT+02:00 Jachym Cepicky <jachym.cepicky at gmail.com>:
>> Cameron
>> I disagree in most of your points.
>> Use case for PyWPS is the same as ZOO or 52North. If it is
>> established and stable, I can not tell - community has to tell.
>> PyWPS is simple and focused application. Maybe we do not have web
>> interface, but we know, where our position is
>> I have no time for this. I've forwarded it to pywps-dev list, maybe
>> someone else will pick this issue.
>> Cheers
>> Jachym
> Hi Jachym
> I think here the problem is maybe a too "pythonic" quickstart without
> any reference to a client interface.
> Is it possible to call one of the sample processes using any of the
> OSGeo Live interfaces?  This way the user has something to play with
> and if interested, can be curious enough to try to modify the python
> code. Maybe it's just a matter of having a simple OpenLayers or
> Leaflet viewer that calls a process et voilà.
> Hope it helps.
> Jorge Sanz
> http://www.osgeo.org
> http://wiki.osgeo.org/wiki/Jorge_Sanz
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/pgp/JachymCepicky.pgp
Give your code freedom with PyWPS - http://pywps.wald.intevation.org _______________________________________________
Live-demo mailing list
Live-demo at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/live-demo
http://live.osgeo.org
http://wiki.osgeo.org/wiki/Live_GIS_Disc
More information about the Live-demo mailing list
