[Live-demo] pywps to osgeo-live
Jachym Cepicky jachym.cepicky at gmail.com
Mon Aug 4 03:52:51 PDT 2014
Thank you Ian,
would be helpful, I could possibly help you in case, you would be
stuck with some issue
Jachym
2014-08-04 12:38 GMT+02:00 Edwards, Ian <ian.edwards at metoffice.gov.uk>:
> RE: PyWPS..
> I need to improve the Iris quickstart (Iris doesn't have a GUI either)
> I could easily adapted our OL2 tutorial from FOSS4G 2013 to work with PyWPS
>   https://github.com/SciTools/osgeolive/tree/master/docs/osgeolive/source/solutions/zoo_rolling_window
>   https://github.com/SciTools/osgeolive/blob/master/docs/osgeolive/source/foss4g_2013/advanced_wps_iris.rst
> This would then give a demo of PyWPS, and the initial demo process would make just make use of "import iris" to read data from an unusual GIS data file (e.g. NetCDF).
> -----Original Message-----
> From: live-demo-bounces at lists.osgeo.org [mailto:live-demo-bounces at lists.osgeo.org] On Behalf Of Jachym Cepicky
> Sent: 04 August 2014 11:28
> To: Jorge Sanz
> Cc: live-demo at lists.osgeo.org
> Subject: Re: [Live-demo] pywps to osgeo-live
> Maybe simple OpenLayers2-based applicaton could do buffer.
>  It should be working with QGIS-WPS plugin too, but, since the standard is relatively underspecified in some fields, there might be a problem.
> Thanks
> Jachym
> 2014-08-04 12:17 GMT+02:00 Jorge Sanz <jsanz at osgeo.org>:
>> 2014-08-04 11:49 GMT+02:00 Jachym Cepicky <jachym.cepicky at gmail.com>:
>>> Cameron
>>> I disagree in most of your points.
>>> Use case for PyWPS is the same as ZOO or 52North. If it is
>>> established and stable, I can not tell - community has to tell.
>>> PyWPS is simple and focused application. Maybe we do not have web
>>> interface, but we know, where our position is
>>> I have no time for this. I've forwarded it to pywps-dev list, maybe
>>> someone else will pick this issue.
>>> Cheers
>>> Jachym
>> Hi Jachym
>> I think here the problem is maybe a too "pythonic" quickstart without
>> any reference to a client interface.
>> Is it possible to call one of the sample processes using any of the
>> OSGeo Live interfaces?  This way the user has something to play with
>> and if interested, can be curious enough to try to modify the python
>> code. Maybe it's just a matter of having a simple OpenLayers or
>> Leaflet viewer that calls a process et voilà.
>> Hope it helps.
>> Jorge Sanz
>> http://www.osgeo.org
>> http://wiki.osgeo.org/wiki/Jorge_Sanz
> Jachym Cepicky
> e-mail: jachym.cepicky gmail com
> URL: http://les-ejk.cz
> GPG: http://les-ejk.cz/pgp/JachymCepicky.pgp
> Give your code freedom with PyWPS - http://pywps.wald.intevation.org _______________________________________________
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://live.osgeo.org
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Jachym Cepicky
More information about the Live-demo mailing list
