[Live-demo] Translate Geomajas documentation
Cameron Shorter cameron.shorter at gmail.com
Sat Aug 9 04:47:39 PDT 2014
Hi Matthias,
During the build process, we check to see if translated docs exist, and
if not, we link to the English documentation.
(See
http://trac.osgeo.org/osgeo/browser/livedvd/gisvm/trunk/doc/Makefile ,
look for "link_to_en_docs")
A crude way to link to English docs is to remove all out of date
translation docs.
I would prefer we don't do this, as we are loosing all the hard effort a
translator has put in place.
A simple and hopefully effective way is to approach the authors of the
translations of your doc and ask them to update your translations.
(Check logs for usernames)
A better solution, which will require some programming is to check
version numbers of English and translated docs, and if translators are
out of date, then insert a line "Please refer to English documentation
which is more recent".
This should slot into the Makefile. You can also refer to
http://trac.osgeo.org/osgeo/browser/livedvd/gisvm/trunk/bin/extract_doc_versions.pl
which is used to build:
http://adhoc.osgeo.osuosl.org/livedvd/translation_status.html
On 9/08/2014 7:07 am, Matthias Streulens Geomajas wrote:
> Then I should propose to set the documentation all to English.
> I try to find out how I can do that.
> Kind regards,
> Matthias
> On 8 augustus 2014 23:01:54 CEST, Cameron Shorter
> <cameron.shorter at gmail.com> wrote:
>     On 9/08/2014 1:47 am, Alex Mandel wrote:
>         On 08/08/2014 12:22 AM, Matthias Streulens Geomajas wrote:
>                 Hello, sadly I saw that the documentation we provided
>                 is not translated correctly from English to other
>                 languages. (Some translations are old rel 1.14 <> rel
>                 1.8) Can someone translate this from English to other
>                 languages? Or should Geomajas do it ourself? The
>                 documentation can be found on the latest release of
>                 the OSGeo 8 dvd. And also here:
>                 http://adhoc.osgeo.osuosl.org/livedvd/docs/en/overview/geomajas_overview.html
>                 http://adhoc.osgeo.osuosl.org/livedvd/docs/en/quickstart/geomajas_quickstart.html
>                 If it is not needed to be translated I can set it on
>                 English for all parts. Kind regards, Matthias
>                 Streulens Geomajas Community System Admin
>         The projects are not necessarily responsible for translation
>         of the docs. Additional volunteers from the project or
>         elsewhere are always welcome to contribute. We keep track of
>         translation status on the following pages:
>         http://adhoc.osgeo.osuosl.org/livedvd/lang_stats.html
>         In the event that page is way out of date we can set that
>         particular page to show the English variant instead. For
>         obvious reasons that's our last option.
>     This raises a good point. I wonder whether we could add in a step into
>     our build process which checks the version of translated docs, and if
>     the translation is older than the English version, we inserted a line
>     "This translation has not been updated to the most recent English
>     version. Please compare with the English version for latest details".
>     Matthias,
>     Some projects do take responsibility for updating some of the
>     translation pages themselves. However, it is not a requirement.
Cameron Shorter,
Software and Data Solutions Manager
LISAsoft
Suite 112, Jones Bay Wharf,
26 - 32 Pirrama Rd, Pyrmont NSW 2009
P +61 2 9009 5000,  W www.lisasoft.com,  F +61 2 9009 5099
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20140809/c50350df/attachment-0001.html>
More information about the Live-demo mailing list
